WTB--The float in the brake reservoir
Drew Gregg
Ft. Lauderdale
My e-brake indicator light kept flashing red. I found the float was half full of brake fluid. The seam must leak so tiny that the fluid will not come out.
Has anyone drilled a small hole in the float to allow the fluid out and found a product that will seal the seam and drilled hole and still allow the piece to float?
Will this new style float work with the original float system? note the 2002 reservoir is the same as the E9 system.
JB Weld is a good idea. I wonder if the float in the EBay pic comes off and will fit on the original assembly. Has anyone tried that?
Discussed in this thread
Drew, we spoke. My float is only partially filled at this point but the rubber grommet is shot. When the time comes, I will use a 27G needle to remove the fluid from the float, piercing along the seam. For now, I have used Permatex gasket maker to replace the grommet, its weight still allows the float to float. I am actually going to let it sit in fluid in a cup for a week or two to see how the Permatex holds up before actual use in the reservoir. If that works, I will use it to repair the seam and 27G hole when I need to.
I wonder if I could use the newer float and just leave a "nubbin" of the plastic shaft and then tie it to the brass shaft using electrical shrink tubing and using a hairdryer set low to shrink the tubing without melting anything. I am going to put a piece of shrink tubing in brake fluid as well to see how that holds up. I used shrink tubing to repair the snapped arm on my glasses, 2 concentric layers, and it has held up for a year. Of course, not caring about making any fashion statements at my age.
Does anyone have a float from an E9 or a 2002 brake reservoir? I would rather get a replacement to put in my 2002 than try to empty and seal my bad float.
All the while this thread has gone on, I did not check my float and bingo, filled with fluid and non-functional. So
1) removed the brass shaft/basket and grommet and could not find a hole anywhere. Perhaps after 45 years, the BF just permeates thru the plastic or thru the seam. There was no hole in the dimple on either the grommet side or other side either.
2) Took a 22G needle and a syringe and placed it into the float via the dimple in the grommet side. This allows BF removal, and I know the hole made will be covered by the grommet afterward.
3) I replaced the brass shaft and grommet, added a pinch of JB weld (perhaps should have used silicone instead) to the dimple first. Been a month, no re-accumulation, float works like it should.
Don sold me the NOS/NLA float assembly---Part# 34 32 1 103 065 is on the box. Thank you SFDon!! He said the fluid leaks into the float through the grommet. Rob's syringe method might be the answer to the float repair. Let's see how his float works in a year. GR8 job, Rob.
