Latest activity
  • enoz05
    FS: Bosch blue tip antenne in very good to new condition. One Original key is included. Price 325 euro + shipping.
  • ScottAndrews
    ScottAndrews reacted to boonies's post in the thread Battery drain. with Like Like.
    If you need to chase further... Connect the Meter in Series with your Battery (route all current through your multi-meter) Disconnect...
  • bluecoupe30!
    bluecoupe30! reacted to boonies's post in the thread Battery drain. with Like Like.
  • R
    Thank you for the explanation @HB Chris. I am familiar with intake runner length and how this affects the torque. My BMW knowledge...
  • ScottAndrews
    ScottAndrews reacted to rsporsche's post in the thread 72 3.0 CS 2240344 Restoration with Like Like.
    if you want more detailed info, check out the FAQ - https://e9coupe.com/forum/threads/speedometer-and-differential-ratios.35162/ in...
  • ScottAndrews
    ScottAndrews reacted to Dlc's post in the thread Some help getting engine started with Like Like.
    I ended up after several years with rewiring the stalks to the later model - now my turn signal sits on the left, and my wiper control...
  • ScottAndrews
    ScottAndrews replied to the thread Battery drain..
    It’s a simple test. Unplug the hazard switch, and try your battery connect test. No spark and you have found the culprit
  • sfdon
    sfdon replied to the thread Battery drain..
    If your door is open, when you connect the battery, you will get that small spark, cause you are energizing the relay for the windows
  • sfdon
    sfdon reacted to HB Chris's post in the thread Battery drain. with Like Like.
    Your window motors are energized when you open the door via a latching relay. If you don’t have the plastic plug on your door to close...
  • sfdon
    sfdon reacted to HB Chris's post in the thread 'C' tube intake manifold(s) with Like Like.
    JP, It is most common to use L-jet parts when switching from carbs to injected especially with a b35. The b35 intake runners look like...
  • Beaudave
    Beaudave replied to the thread Friction fan coupling parts FS.
    Hi guys, I'm not sure whether my friction fan is working correctly. Maybe because we have pretty high temperatures at this moment, but...
  • Beaudave
    Beaudave replied to the thread Wheel Alignment Specs.
    Thank you @sfdon. That's what I was looking for too.
  • Beaudave
    Beaudave reacted to sfdon's post in the thread Wheel Alignment Specs with Like Like.
    Here ya go- toe only available unless you get fancy.
  • RichenFamous
    RichenFamous reacted to Bmachine's post in the thread WTB: A New Daily Driver with Like Like.
    Wagons / Tourings are the best. And the fastest...
  • RichenFamous
    RichenFamous reacted to autokunst's post in the thread WTB: A New Daily Driver with Like Like.
    Just sharing an update. I began with a list of about 100 things I would like to (or need to) do to the car. As of today I've put about...
