Latest activity
  • ScottAndrews
    ScottAndrews replied to the thread Manual trans questions.
    Yeah, this seems like a great solution, and the fact that you can do a paddle type shifter makes the driving experience even more...
  • Rudy3.0CS
    Rudy3.0CS replied to the thread Manual trans questions.
    Well, the actuated clutch option seems way more complicated and uncertain. An automatic that actually works (and the flasher stalk idea...
  • ScottAndrews
    Me too!! So the actuator is pretty simple. I assume there is a transfer function that converts applied voltage to linear motion. If it...
  • ScottAndrews
    ScottAndrews reacted to StephenZ's post in the thread Manual trans questions with Like Like.
    Yeah, that probably makes the most sense...Although, I do enjoy the idea of the engineering challenge of the actuators...:-)
  • StephenZ
    StephenZ replied to the thread Manual trans questions.
  • StephenZ
    StephenZ reacted to ScottAndrews's post in the thread Manual trans questions with Like Like.
    That sounds like a MUCh easier setup.. Repurpose the flasher stalk to use as a paddle shifter!!
  • StephenZ
    Yes, the force is at the clutch fork. The reason I suggested measuring the pedal force is because that's easier. You measure the pedal...
  • ScottAndrews
  • ScottAndrews
    ScottAndrews reacted to Rudy3.0CS's post in the thread Manual trans questions with Like Like.
    You could also us a ZF 4HP22 auto. The electronic version has electronic control. Compushift makes a dedicated ECU for that...
  • ScottAndrews
  • StephenZ
    To verify, the clutch pedal force would not be recorded at the pedal, but rather at the bellhousing to push the actual clutch fork, as...
  • D
    D Calkins reacted to Rudy3.0CS's post in the thread Manual trans questions with Like Like.
  • BarneyT
    BarneyT reacted to rsporsche's post in the thread New Member with Like Like.
    Mario is Mario Langston - Chris Langston's father
  • sfdon
    sfdon reacted to Rudy3.0CS's post in the thread Manual trans questions with Like Like.
  • eriknetherlands
    eriknetherlands reacted to mulberryworks's post in the thread Coupe Tools with Like Like.
    I just picked up a very similar wrench from ebay for $9, plus 48 state shipping of course. It's a 14-17mm not the 15-17mm posted above...
