What would you pay for a pair of high quality reproduction tail light frame/lens
Stan,
Thanks again - given the likely wait, I have just sourced a near new light from the US so won't progress with this approach for now - thanks again - and keep up the good work.
I hope the 88 is lucky for someone else soon
Best
David
My 1971 2800CS is finally ready to be shipped to me next week, but I know I need some tail lights. Please put me on your list.
Rich Becherer: rich dot becherer at yahoo dot com
Thank for all your work on this project!
The guy making them has not replied to my emails in months. The last time I heard from him, he told me he was going on a 2 week vacation and then would make and send more. He might yet surprise me but so far, nothing from the last 5 emails
It would be a pity if this solution disappears. Has anyone successfully removed their existing lenses and fitted them back?
it is very difficult to remove a set very cleanly to allow resetting after rechroming the frames. i have had the best luck with a butane hot knife. you have to keep from creating a jagged edge while cutting the folded / melted lip of the original lenses ... as if it is not smooth, it will telegraph through the lens when reinstalled which doesn't look very good.
that being said, if Stan's guy remains AWOL and doesn't complete the order. i will try to take a set that isn't that good apart.
I met with Daddywad at the Sharknose meet up at the Ace cafe in North London yesterday. There were quite a few E9's there and it was a lot of fun.
Daddywads solution was to melt off or grind off the overlap of the lens to remove them. After all the work is done to the metalwork, he refitted the lenses and then used a two part epoxy to run a bead between the rear of the lenses and the metal housing. Once I confirm the products, then that's my plan.
His car is quite amazing and one of the best BMW's classics I have ever seen. I will never achieve his standard, but it gave me the spirit to keep trying. Some rather average pictures of some really nice cars, and my sad unfinished project standing out like the black sheep of the family.
The final picture is of a car that is comprised of all speakers and woofers. It's obviously a marketing tool as to have those babies running whilst in the car would reduce your brain to mush. The guy cranked it up whilst we were there and it was registering on the Richter Scale.
Rek,
you will have to grind off 3 sides of the brake light or back up lens, only leaving one side still applicable to get the lens out. i have seen lens that was ground out with a dremel tool and it didn't look that good. perhaps once the lens is out you can smooth the edge and polish it, then it won't look messy when its reinstalled. i would practice on one that has a cracked lens before trying it on a good lens.
one word of caution, the thickness of the new chrome can make the old lens not fit so well - sometimes the new chrome is thicker than the original.
Rek,
Thanks you in advance for the good advice. I have had that issue with chroming before and machining it can ruin the finish around the edges.
Hi Stan, thank you for your reply. I would like to have a set order for my 1973 CSL RHD, please.
I have....
To get the lens out I used an air grinder ( like a Dremel) with round end TCT bit in, and ground off three sides - the top and the two sides on each of the of the lens , however the indicator lens you need to grind off the curved bit...- you will see the excess of plastic that holds the lens in..
Lens pop out and you can clean them and set aside for re fit
Frames went off to chrome..
Got them back - put the lens back in and glued them in ( from the back) with a clear epoxy glue - held in place with masking tape until set.... easy job...
All the bits ready for install
You can see where I re glued the lens in, and with the indicator where I had to grind off the plastic to get it out - the clear epoxy glue gives it away - it did turn milky when mixed!
Glued and held in position with masking tape
All dry and finished -
three more sets on their way from OZ
so now I have 4 sets.
two sets have red turn signal lenses
I will reach out to the next people on the list.
The guy said his plan is to ramp up production but I am not holding my breath
