Need all 20 of them to replace the short studs in my rotors on a 3.0CS. Bought 16" BBS wheels and need longer studs to mount them.
I like your new BBS Mahles Gregg! Gold on blue should look nice!
These may be a bit long.
http://www.iemotorsport.com/bmw/item/12x65arppressin.html
Much cheaper - same quality brand:
https://www.summitracing.com/parts/...MI-M2DwrOE4AIVVx-tBh1hlg9iEAAYAiAAEgI6uvD_BwE
Well, took some time to locate these in the parts stash, but perhaps these will work , they are not perfect, but they are Momo brand, and there are 20 of them :
View attachment 58766 View attachment 58767 View attachment 58768
I need longer lug studs,but thanks for the offer for the lug bolts. I have those lug bolts on my '01 X5 and it's a chore to mount the wheel and then thread those bolts into the hub.Well, took some time to locate these in the parts stash, but perhaps these will work , they are not perfect, but they are Momo brand, and there are 20 of them :
I have gold basketweave wheels on my Malaga 2002. I'm thinking of a titanium metallic gray with polished rims for the Blue Coupe. your thoughts?I like your new BBS Mahles Gregg! Gold on blue should look nice!
Great sources! Note the studs at both sites are the same 265mm (2.60")length. The OEM stud is only 48.5mm long. Where can I buy those drilled & slotted rotors? And where did you get new calipers? I might need them. I also found a company that makes lug studs--Dorman. Don't know yet if they make a 2.60" stud.I used the summit racing ones also. Same thread pitch and longer. Running BBS RS also and the studs are fine. View attachment 58587
Thanks for the web-sites. The gold centers look good on your red car.I like your new BBS Mahles Gregg! Gold on blue should look nice!
Markos--I did see these wheels and wish I could have bought them last November. The BBS wheels I bought on the BAT auction are the same made in 1983. The ET11 clears the front strut by about a inch. Where did you get the rims polished? I found a guy in Texas that strips the wheels to bare metal and paints the centers and polishes the rims like your silver wheels. But his prices are pretty steep. I'd like to find another source. Thanks, DrewI think they will look good. Gold on blue looks great also.
Take a look at this thread for a peak at silver with polished lips.
https://e9coupe.com/forum/threads/s...-staggered-bbs-mahle-w-new-tires-1-000.30103/
If you just want to fit-test the wheels, you can buy a set of nuts like these:
View attachment 59229 View attachment 59230 View attachment 59231
Markos--I test fitted the BBS on my stock hubs. The studs barely let me screw on the OEM tapered lug nuts. The stud was 16/32" short in the front and 13/32" short in the rear. I measured the depth with a tire tread gage. So I need 1/2" longer studs. Or can I use these extra thread lug nuts you have pictured? Where do I buy them? Could you possibly lend me one nut to see how many turns I can get on my existing studs to make sure this is a safe way to avoid tearing apart the calipers? Thanks--pics here to show you the wheels on the lug studs, and 2 OEM lug nuts screwed down in the tapered holes .I think they will look good. Gold on blue looks great also.
