2.5 cs automatic transmission
How does $500 plus shipping for the two sound? I'll also throw in a speedo drive cable and a gearbox mount bracket, though you will have to source a gearbox speedo drive.
Gazz you still got this box ?
we are talking about a 262 four speed yes ?
Yes I still have the box. I can take some pics if you want and send them to your email address. I know it came out of either an E9 or an E3. How do I verify it as a 262 4 speed?
Not sure how I'll ship it. I guess I could make up a crate out of pine studs screwed together.
Plastic bins work well and super cheap.
Thanks Don. I feel like big brother is watching. A good big brother that is, the kind you want watching, not the Orwellian one.
Unless you are secretly working for the Dept of Public Enquiry, DOPE, a quasi non governmental organisation, QANGO, that monitors public information via early algorithmic response systems, EARS.
Having revealed that I suppose I'll be on the candidate hitlist utilising missing person statistics, CHUMPS. And all because of a gearbox!
Here you go. Definitely a model correct 262 4 speed. Turns freely, no crunching or resistance and no leaks.
Unfortunately I no longer have the drive cable or the pedal box. I would try Dean at Peninsula BM for those plus any other parts for a conversion. Manual box transforms the car. If you get stuck I may be able to source a pedal box and a bell housing locally.
And you don’t need to change the pedal box, it should have a designated punch out hole for the clutch master. 74 got the huge spring version, you need both pedals and the long bolt.
I have sourced a pedal box and a bell housing both of which I can get immediately. Still in negotiations over $. May be able to get some shifter parts.
$150 for the pedal box and bell housing. I can get pics if I can work out an excuse to travel there. It's not far. Where are you?
Hi all...
My 74 2.5cs auto is a very original car and I might just keep it that way, not 100% sure yet but just considering it as an option, so today's question is ;
The auto box that's in this car?
What is it?
And what other models was it used in?
Any auto experts out there?
Andy
Hi Andy,
were you looking for a 2.5 badge for your car? If so, you can buy a new one from Christoph.
