Power steering pump rebuild
Honolulu
Honolulu Hawaii
Finding this is SOOO timely as I have my PS system drained. It was groaning excessively and the oldtimer I chat with recommended complete fluid replacement rather than just topping up. A change worked well for the E30, now for its older brother.
Sam Lever
Nice one Steve! I recently replaced the nose shaft seal on mine, as it had begun to leak in a very tedious way. I agree with you re the roller bearing. I thought it was a joke at first, but managed to get my rollers to stay in place with a little grease while the shaft is reinserted, otherwise they kept falling out and testing my vocabulary! No leaks now and a bit quieter on new fluid too.
dhanna
San Diego
this is awesome I just ordered what I could of the seals and bearings that are still available at the site listed above but what about the steering box itself is there a good source for all the seals and bearings for the power steering box itself?
Honolulu
Honolulu Hawaii
I found that rather than just replacing the fluid in the reservoir, a complete drain and refill made my groaning go away. But I think in my case, simply driving more often would be the hot ticket. We all know coupes in particular and early bimmers generally, all need regular exercise. Just like their owners.
Mark Wilson
New Zealand
Hi, I have my parts and have taken the key and the circlip off the front and back, now how do I get the back off?
All help accepted.
Mark Wilson
New Zealand
All help accepted.
Well, I managed to get the back off eventually, A think it had been put on with shellac. I managed to clear it off and then pop the back off with a bit of air pressure ( it always makes you jump).
The rotor housing was a real pain to get off, but I managed it and now I'm stuck on the backplate. I made a bit of a puller, but it bent under strain. So I think the previous repairer might have used some more magic to seal it in. I was thinking about putting some heat on it.
Thoughts please?
Thoughts please?
photos please ?
it will make easier to help
Gazz
Gold Coast Australia
All help accepted.
Mark, just in case - On Oz Ebay, this -
BMW 2.5CS-3.0CSL Coupe Power Steering Pump Fits up to 04/1981 Ref Part 1124085
eriknetherlands
Netherlands, Eindhoven area
Might i suggest moving this post into the DIY section? It's been a very helpfull explanation by @Stevehose ; as I'm about to do the same this is helpfull to understand how it all goes out and in again.
My pwr str pump has no problem, im going to rebuild it for peace of mind as it's out of my car anyway....
Thomas76
Michigan, USA
Knocking the dust off this very helpful thread I found the cap seal/oring is now obsolete.
32411105157
Google is not steering (no pun intended) me to a new part #.
Does anyone know specs on the oring? Realoem doesn't provide one.
Ohmess
I wanna DRIVE!
Aiken, SC
If you can find the dimensions, I have had good luck with orings.com.
Thomas76
Michigan, USA
I've used them before and have a shopping cart full of guess sizes. Thanks!
I am guessing on size and would probably buy a few sizes in the ballpark.
Really hoping someone knows the exact size.
Barry.b
Ireland
32411105157
Hi Thomas
I think I listed the size’s when I rebuilt my one .
Hopefully it might be helpful for you.
Thomas76
Michigan, USA
Hi Thomas
Thanks for reaching out, I reviewed the post and found the picture of receipt. There are multiple 2.62mm orings with diameters very similar, I'd still be guessing unless you know which one specifically landed in that pump cover?
Barry.b
Ireland
Hi Thomas
Unfortunately I cannot remember which one went where as I replaced all of them at the time.
eriknetherlands
I ordered most/all of the replacement parts one or two years ago when this wonderfull thread was started. I still have them in a bag - I'll measure that one (32411105157) up for you this evening.
Here is the measurement; it looks to be 2.6 mm thick.
The ID/OD can't be measured, as it is sooo floppy.
Perhaps it works as follows: if the O-ring is half burried in the housing (an assumption; needs a check), one could measure the ID of the hole, and add 2.6mm to get the OD of the ring.
Thomas76
Michigan, USA
Thanks! I'll give it a go and post results with part number when done for the next fella.
Thomas76
Michigan, USA
Update:
I bought 2.5mm orings from orings.com, they did not have 2.6 or 2.7 in the correct od.
The new oring does not seal the cap. :(
2.5mm is noticably smaller than 2.6 and I believe that could be what went wrong.
The design intent appears to have the cover pushed against the oring, not through it if that makes sense. The snap ring places a squeezing force on the oring that doesn't happen with the smaller diameter.
It is also possible the mating parts are simply old and worn creating slop that a new oring won't fix.
