Lan-Engine M30B30 tuning thread, steps, values, specs, and so on
... after all this inmense job, (it started september the 20th), just last week i was finally able to put her on the ground with clean tyres
i was expecting to check the engine start on the first day of 2021
but,...nothing
at the beginning it was quite normal to expect some time to fill the filters bowl, and the carburetor reservoirs, but that point was far passed and indeed no sign of spark, combustion, or explosion of any kind
what was happening ?
we had fuel, plenty of it, so electricity and more specifically ignition came to my mind as the possible culprit
but i am very meticulous, true is that i removed the distributor to clean it, but i was very careful to remove and put it back again,...
if you look closely here you can witness the mistake, but it is not so obvious, as the alignment has to be made between two parts separated 40mm in height
i started checking the details for a bad connection, an incorrect value,...all in vain,
but when i placed the OT mark in its place....
i found that it was quite a surprise ....
the rotor was not perfectly centered, it was off probably less than 5mm,...
but is this relevant, at all ?
so i took the haynes advise as how to set static timing by means of a test lamp
and prepared my setup using a 12volt test lamp
it worked very well
set your engine at OT as previous pictures shown, slacken the clamp bolt so you can rotate the dizzy, first you turn the dizzy clockwise far enough so you are sure that points are closed, then you switch the ignition on and then very slowly turn the dizzy anti-clockwise until light is on, and there fix the clamp bolt
you get a couple of extra checks using this trick, first is you have light so you are sure that there is electricity going on there, second, you will hear a loud click as the HT lead produces an arc, that means that your coil is working
you can see that this job meant that i just turned the dizzy body clockwise an equivalent to those 5mm, which meant effectively putting the mark in the middle
put everything in its place again, and then the engine started like a champ
amazing, problem solved
my recap,
it seem to me that when i fitted the dizzy back in its place i was too much influenced by the position of the body according to the alignment marks that i always do during stroboscopic timing procedure
but as you know the rotor turns freely while you are introducing the dizzy back in its place, this is why you should pre-set it 35mm before the mark
the whole operation is a bit complex as you are introducing the dizzy rod into a very tight cylinder with a rubber seal on it, so errors can occur
my guess is that even being very careful i slipped just one helicoidal tooth of the gear and this produced the slight misalignment, which was finally corrected by rotating the dizzy body during the static ignition setting procedure
moreover the check that you have to perform to see that the mark on dizzy body is aligned with the centre of the rotor plate is tricky, as both elements are separated in height around 40mm making very difficult to make a proper alignment that will always be influenced by your viewing angle
....your thoughts ?
thank you
some pics from manual.
here is the removing and refitting procedure
finishing this with ignition and synchro:
photos afre self explaining, copied it from our local forum.
dwell 34,8 grados,
reajusto el delco con 1700rpms y strobo a bola (22 BTDC)
- 1/4 de vuelta
[IMG]
[IMG]
a 1700 rpms
[IMG]
18kg/h de aire
[IMG]
[IMG]
y el CO en 2,7%
[IMG]
a 980 rpms
[IMG]
un poco menos de 12 kg/h
[IMG]
[IMG]
y 3,1 a 3,2 % de CO (valor correcto entre 3 y 4%)
[IMG]
la instalacion incluye una cartulina para evitar que el carbu delantero se vea afectado por el ventilador
[IMG]
while we are here,
i use two markers,
first check, if ok red mark, if not i fix it and paint red mark
once done, i make a complete turn to recheck
if ok i paint a blue mark, if not, fix once more, a new recheck turn and if ok a blue mark
but in the first turn, the exhaust valve of the second cyl gave a wrong check, so i had to fix, and the nut was too big for the wrench, WTH ?
There is a one mark (triangle) on the oil supply line which should be on the front side. (Driving direction).
If it is on the other side the oil drops fall next to the lubrication point.
i wonder what is the purpose of your explanation
maybe you are complementing something, or maybe not,
for your detailed reading, my engine has not triangle, it has a clear nice sign with the word “front”
you can see it at the beginning of this thread
Jesus- I looked at 2 engines yesterday where the oiler bar was installed backwards by the engine shop. Very sad. We see it every year over and over.
Forum members need to know that oiler bars are asymmetric- The tiny arrow is the tell. Do not trust the big arrow.
They probably will never see an oil bar like yours- we know it is not factory because “front” is not a German word. Your bar looks expensive and nice.
I’m in Spain on the 27th, back to Porto and then Mijas working the first week of December.!
There is a car you would like there- maybe you can visit?
Hello deQuincey,
My post was only complementary to the forum members.
Your post is very useful for members and e9/e3 fanatics. It takes a lot of time to make such a post. Thanks!
Mit freundlichen Grüßen/with best regards
I’m in Spain on the 27th, back to Porto and then Mijas working the first week of September.
assume that you are visiting portugal and spain from November the 27th - on at least until first week of december. (setpember might be a misspell)
very kind of you, but mijas is too much far away from my place in Das Baskenland, that is another continent, i wonder how was the flods over there, valencia is war zone now
good luck
if you come to the north please do tell
