1974 3.0 CS With M88 Engine (3.5 CSM)
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 24, 2021 #21
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 24, 2021 #22
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 24, 2021 #23 Use expanding foam, then trim smooth, to make the transmission tunnel smooth and easier for carpet to lay flat. RP
Rek Well-Known Member Messages 1,119 Reaction score 356 Location Islington London England Aug 25, 2021 #24 I like the idea of using expandable foam. It is used so much in luxury cars nowadays. I like that engine too!
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #25 Rek said: I like the idea of using expandable foam. It is used so much in luxury cars nowadays. I like that engine too! Click to expand... Thanks, Rek. I used the foam in the pedal box area, too, to eliminate the big hump, letting the carpet lay smooth. RP
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #26
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #27
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #28
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #29
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #30
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #31
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #32
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 25, 2021 #33
paul Well-Known Member Site Donor Messages 321 Reaction score 305 Location Australia, Queensland, Gold Coast Aug 26, 2021 #34 RP....did you have to modify the firewall to fit the engine in ??
tferrer Well-Known Member Site Donor Messages 2,153 Reaction score 2,336 Location San Francisco, CA Aug 28, 2021 #35 Perhaps I missed it but where you going to replace/restore the wood dash?
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 29, 2021 #36
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 29, 2021 #37 Paul, no firewall modification was necessary. tferrer, the wood was replaced with a thin, bendable sheet of machine -turned metal. RP Last edited: Aug 30, 2021
P Patton Well-Known Member Site Donor $ Messages 757 Reaction score 646 Location Atlanta GA Aug 29, 2021 #38
tferrer Well-Known Member Site Donor Messages 2,153 Reaction score 2,336 Location San Francisco, CA Aug 30, 2021 #39 Got cha. That wood looks awful good in the coupes!
Belgiumbarry Well-Known Member Messages 1,618 Reaction score 1,117 Location Belgium Aug 30, 2021 #40 does that M88 engine needs a "speed" signal to his ECU as it gets it from the diff in a oem M5 ? which of course you don't have in a E9 diff.
