David, Red? And keeping Motronic distributor? Enquiring minds want to know more.Since we’re sharing M90 candy….
Beautiful engine bay 3.8l very nice, are you using a m88b38 crankshaft to achieve thisNow here's an m90. 3.8l Megasquirt and fun!
Very nice engine build looks beautifulAND I second the OCCoupe gorgeous engine bay!
Yes, I was able to source one from BMW. It created a few problems since it used a different harmonic balancer with a 4 bolt setup.Beautiful engine bay 3.8l very nice, are you using a m88b38 crankshaft to achieve this
It’s absolutely beautiful! where did you source the itbs from ?!Thumbs got in the way…
“ ITB’s might be more interesting anyway than the red - lol! “
So did you have to find a s38b38 harmonic balancer or make an adapter?Yes, I was able to source one from BMW. It created a few problems since it used a different harmonic balancer with a 4 bolt setup.
Yes, at that time BMW still offered the balancer and hardware. The amazing part was the cost for the crankshaft from BMW was $855.00 which included the bearings.So did you have to find a s38b38 harmonic balancer or make an adapter?
in my opinion the abundance of b35 blocks make it a way cheaper better option, heads breathe better on a b35 and if you bore it like an m90 you'll have more hp as long as compression stays the same but forged custom pistons are expensive but you would be able to bump up compression a bit, to use a old style distributer on a b35 you'll need a timing cover a dizzy rod and an adapter nut from the older enginesI don't have a M90 block to tell, but perhaps the group here can tell me; are there any structural differences in the M90 block that make it a preferred option instead of boring out a M30B35 block? M90 blocks are pretty thin on the ground these days.
Shameless hijack, so apologies, but I have a couple of M90 block and crank combinations to clear. One is a non-extended water jacket type, and another with the extended water jacket. Also have a few heads / sets of pistons/rods etc if someone is keen.I don't have a M90 block to tell, but perhaps the group here can tell me; are there any structural differences in the M90 block that make it a preferred option instead of boring out a M30B35 block? M90 blocks are pretty thin on the ground these days.
The bore and stroke of a b35 are different than a M90 block.
The water passages are different at deck of block of M90
The head gasket is different because of this.
The water outlet on a b35 block is missing
you want more![]()
B35 has the best flowing head out of any m30 period. With custom pistons it’s a no brainer , unless your going for insane rpms aftermarket aftermarket rods are very expensive and not needed, I know turbo guys doing 585whp on stock bottom end m30s
Wanna be safe, get arp rod bolts if you wanna spin high rpms with the stock rods
M90 is a great engine. B35 is a better foundation if you don’t mind making one custom motor Mount, you can bore out the b35 much more than you can bore an m90 , m90 is basically already factory bored out with a shorter stroke like don said
