4310316 begins
aearch
pleasant hill , ca
SO WHERE CAN I GET THE EXTRA 8K
HUMMM
GUESS ITS NOT A REALLITY
HAVE TO FIND A UNIT FOR 10K IF POSSIBLE AS THTATS ALL ILL HAVE FROM THE
SALE OF THIS ONE.
aearch
pleasant hill , ca
SO MY OPTIONS WITH THIS MOTOR SEEM THIN AS I DONT HAVE THE 5K UP FRONT TO
GIVE TO LOGAN SO ILL GET THE 10K FROM THIS SALE AND
GET A 3.5 REBUILT READY TO GO FOR 10K
IS THIS A SOLUTION WE CAN ALL AGRREE ON?
aearch
pleasant hill , ca
SFDON I WANT THIS OFFER IS IT STILL AVAIL
I JUST NEED TO GET THIS UNIT OUT AND THEN ILL HAAVE THE MONEY FOR YTOUR UNIT
HOW DO WE DO THIS?
I suggest that you sell your lump for whatever you can get for it. You will want proof of life with a spinning motor if you want anywhere close to $10K IMO.
I still think the absolute safest bet is a known running 3.0CS with carbs. The motor
will be nearly free, and you can put that s38 money towards the gremlins that are guaranteed to come up after getting your car on the road.
If you are hell bent on a 3.5L, don’t buy a long block. I’ll repeat. Buy a running e34 535i, or e32 735i. Swap the motor and factory he harness over. You can get a donor for $5K or less with under 175K miles. Save those s38 funds for a refresh if/when you see issues.
Tim M
This thread needs to have a warning!
Enter at your own risk and NOT responsible for Keyboard damaged cause by reading ThREaD!!
Where is the number matching motor to this Car?
aearch
pleasant hill , ca
ILL GET THIS OUT AND THEN GET THE 3.5 SOMEWHERE
WHAT DO YOU MEAN DONT GET A LONG BLOCK MARKOS
I NEED THE WHOLE SETUP HARNESS ECU OF COURSE
ILL CALL MIKE HAVE HIS NIMBER
He means what you're also saying. Get a running and driving car so you have everything you need to do the swap (mostly).
To be more specific, buy a cheap e34/e32 that runs and drives. One that you can personally test the motor, and even get a PPI if you want. Once purchased, pull the motor and have pick and pull take the carcass. Call to ensure that they will pickup on a bill of sale and original title.
aearch
pleasant hill , ca
IS THIS GOOD?
aearch
pleasant hill , ca
I HAVE THE ORIGINAL
ITS SMOKES LIKE CRAZY THATS WHY I STARTED THIS WHOLE MESS
aearch
pleasant hill , ca
I HAVE THE 5SP OVERDRIVE
YA MARKOS
THATS THE BEST IDEA
DO I NEED A SPECIFIC YEARS FOR THE MOTOR
OR WILL ANY 3.5 WORK?
YA MARKOS
THATS THE BEST IDEA
Firstly, don’t buy a car or motor from
Ohio. Anyone who has spent a significant amount of time in CA will go into shock after buying a 30yo car from the rust belt.
Read this, it will help.
Don’t waste your time with a B34 or older. Good motor but a B34 is bolted to a car that will cost more than a B35 based car. Same for B32’s. Plus, a B35 has more power.
Wes
Tasmania, Australia
I HAVE THE ORIGINAL
My suggestion. Keep it simple.
If you have some (or will have some ) cash from the sale of your hot motor put it toward a rebuild of your smoky matching numbers engine. Any decent mechanic can overhaul those motors and the parts are all cheap. For all you know the smoke might be a relatively simple fix. Depending on your budget you could even hot it up.
