- Messages
- 422
- Reaction score
- 264
Hello Coupers, and Don/Chris, Sven, etc. it's been a long time since my last post because, honestly, my E9 has been running perfectly for so long now. But ever since her return from a movie opportunity over 2.5 months that I'll post up about early next year before its debut, she's been running terrible. It occurs when she's warm or cold and the ignition or fuel seems to cut out abruptly and sometimes restores itself -- but usually not and I have to restart. Specifically, she will stutter or stumble briefly with the tach cutting to zero and then return to normal about 5 or so seconds later; other times she cuts out entirely under steady throttle and I have to restart her at speed which might take 2 or 3 attempts...I originally had it towed in to the shop about 3 weeks ago as the intermittent cutting out was so bad I was fearful of making it to the shop.
My local shop replaced what they suspected was as a faulty crankshaft position sensor and fuel temperature sensor to start and it appeared to solve the issue. But they claim it came back getting the car ready to return to me and so they next looked at the ignition switch (per the advice of Chris at Don's shop). The switch was not in great shape and they eventually tried to replace it with a new unit I had Chris send to the shop, but that unit didn't work with my setup and so the mechic cleaned out and rebuilt my current switch...they claimed the car was running well after that, but I don't think their test drive was long enough.
I just returned from picking my car up and the first 20 minutes or so on the ride home she seemed like her old self. Then, the sputtered very briefly and returned to normal rpm. The next time it was a longer period of the power cutting out, the tach went to zero and she returned to cruising on her own, if I recall. I should have turned around and headed back to the mechanic at that point because, after that, she died more frequently and only a restart with 2 or 3 cranks would get her going.
After two experiences like this, it seems to arise after the car has been driven for 15 to 20 minutes, although my mechanic saids it started and then stalled when cold at last once. And it seems to get worse the longer I drive her which perhaps means a heating issue at a faulty relay?
Other background - my car got a new Megasquirt ECU in May along with fortified connectors, plug wires and spark plugs. Prior to that, a new distributor cap and rotor was installed. Prior to the movie scenes, she was really driving perfectly.
I'm going to try and drive her back to the shop today (and data log along the way for Chris/Don) as it's a work holiday for me and my local mechanic will do some more checks on the ignition and fuel delivery. I'l need to check with Don and Chris also to see what they think for next steps. I'm hoping it's a simple relay problem and I'll bring spare fuel pump and ECU relays with me when I go back to the shop.
I'm getting a little nervous now since Legends of the East is coming up soon and there's no way I can take my car in her current condition.
Thanks for any help on this very strange problem!
Wayne
Wayne
