Coupe Underside Paint
We need a definitive answer as to which paint colors and other materials were utilized when our coupes were assembled. I am starting this thread to gather proof as to what is correct. Please reply if you know for a FACT which is correct, I am not looking for speculation. I have seen many different combinations, just look at BaT, but there are very few truly original coupes still out there. It is possible that City Pack cars are different from Lightweight coupes as well. I have talked to a few knowledgeable coupe owners as a start.
Ultra-lightweight CSL:
Front and Rear Valance: Satin Black, no body Schutz
Wheel Wells: Body Color, no body Schutz
Underbody: Body Color, no undercoating
CSL City Pack:
Front and Rear Valance: Body Color with Schutz
Wheel Wells: Black with Schutz
CS/CSA/CSi:
Wheel Wells: Body Color with Schutz (several early 2800CS reported to have black wheel wells)
Underside: Grey Undercoat over khaki primer
Once we have consensus I will delete this thread and create a FAQ thread.
Chris - perhaps we merge it with the FAQ -
E9 - Color placement - what color goes where?​
My City Pack (RHD) car had a grey rubber type stuff all underneath it. Car had never been touched before I got it - assuming was OEM.
Have some pics somewhere.
I thought ultralights had some kind of light bedliner that was c=same colour as the body and BATs had something similar but in black.
Happily stand to be corrected.
My Euro. Grey rubbery stuff over khaki primer
73 CS
U.S. Market 1974 Coupe with 33k original miles. Patricia Mayer, the one owner car. This is the original stoneguard. On this example it is flat grey.
I know it would be extra work to keep the information current, but could you add product info? For example, it looks like Wurth is no longer making grey - or at least, all I can find right now is the black stone guard.
You can still get grey, I just bought some.
We will never know the brand but Wurth looks correct.
I think we know for sure what was on US coupes, khaki primer and light grey undercoating. Just not sure if euro coupes got the same application.
My 4/70 2800 CS (2270237) had never been restored or repainted. It has black paint in the wheel wells and it was done before anything was installed on the car including the bumper brackets, any of the clips that hold the wiring harness on the inner fender, any of the grommets for the brake lines or even the subframe. No overspray on anything. The rest of the car (floors, etc) has the normal schutz color. 2270236 was done the same way from the photos I have received of that car.
CS/CSA/CSi:
Found this thread while researching the factory undercoating to understand what I'm working with on my coupe. Figured I'd post up what I found.
Mine car is a 1974 US-spec 3.0 CS. It's pretty low mileage and lived in the hot & dry climate of Sacramento, California for its whole life. It's surprisingly original and clean underneath the grime. That's all to say I have no reason to suspect the undercarriage has been restored or re-coated.
I found what Chris described to be true for my coupe: grey undercoat on top of a khaki primer.
As many people have experienced, the grey undercoat is peeling away in some spots. Is there a preferred coating that I can use to spot-treat the bare primer spots? I've seen "Würth Stone Guard" mentioned, but I'm not clear if this is the right application for it. It doesn't need to be a correct, concours solution— I'll save that effort for when (if ever) I get around to a full rotisserie resto.
Wurth gray stoneguard (sold online in many places as “Porsche wurth stone guard”) looks very similar to the original material used. I used it on my underside and was satisfied. It is not quite as pebbly or rubbery but gets the overall look right.
