Does rod knock get louder with higher revs?
Skiver
Vancouver, Canada
Trying to upload a video of the knocking sound but having difficulty loading from my phone.
When I pull the spark plug knocking sound goes away and engine runs more smoothly and less vibration at idle.
However I thought rod knock gets louder with higher revs?
With higher revs the engine runs a bit smoother.
Compression on cylinder 3 is within 5% of the other cylinders.
I did valve adjustment and when I put everything back, engine idle is rough. Sputters a bit but keeps going but lots of engine vibration.
Any thoughts if it’s rod knock or something else?
If you really have a rod knocking, you oil pressure will drop.
Better nor run the motor anymore if you really habe a knocking rod.
Did you pressure lamp is on at idle?
For sure, a rod knocking becomes louder.
Especial, it sound harder when rev up.
You hear a beginning rod bearing fail as best with short hard rev up, only up to 2000 really short.
Take a long metal rod and lay it on the lower engine block and the other side on your rear, the perform short hard rev s.
Make a YouTube video and link it here
Breiti
Breiti
You need to remove fan belts and try with cold engine
Sometimes rod knock actually lessens with higher revs… as the rod sort of self centers with higher revs. Louder or more pronounced at idle. Eliminate all other noises as the wise one above said but don’t run it a lot.
Uploaded video here.
You should be able to hear the knocking.
I did use a stethoscope and sound seems to be coming from top end?
Also no oil pressure light.
Make another video with short hard rev. As I wrote before.
Did the oil pressure lamp at warm motor is on?
I put all the belts back and knocking sound comes back.
Used stethoscope and it’s not power steering pump, nor alternator, nor water pump.
Time to grab the 36mm socket.
If it’s loose you may have to dress the threads
When I pull the spark plug knocking sound goes away and engine runs more smoothly and less vibration at idle. However I thought rod knock gets louder with higher revs?
With higher revs the engine runs a bit smoother. Compression on cylinder 3 is within 5% of the other cylinders.
What prompts you to assume that your engine noise is a rod knock? Is the engine seriously worn with low oil pressure? A rod knock may be alarming, but it is not necessarily accompanied by a misfire or “rough running.”
Your description of the problem is difficult to follow and suggests a problem unrelated to a rod knock. You state that when you pull “the” spark plug, (1) knocking goes away and (2) engine runs more smoothly and less vibration at idle. Are you describing each cylinder or are you focusing on one specific cylinder? Are you removing the high tension lead to the spark plug to disable that cylinder, or are you removing a spark plug? If you are somehow disabling a single cylinder by disconnecting a spark plug lead, it is hard to fathom how that would result in an engine that “runs more smoothly and less vibration at idle.” Ordinarily, if disconnecting a spark plug wire results in a smoother running engine, that “possibly” suggests a mixed-up firing order and crossed spark plug wires.
You state performing a valve adjustment, “and when I put everything back, engine idle is rough.” Was the engine idle rough before the valve adjustment? To what values did you adjust the valves? Was the adjustment performed cold - or hot?
In another post you state: “I did use a stethoscope and sound seems to be coming from top end?” Later you say: “I put all the belts back and knocking sound comes back. Used stethoscope and it’s not power steering pump, nor alternator, nor water pump.” A rod knock is apt to be loudest where each individual rod connects either to a piston or the crankshaft. Have you directed your scope near these areas? The fact that you apparently hear a noise “only” when accessories are connected would suggest that is where your (perceived) problem lies. Since alternators, power steering pumps and even water pumps can make noise due to worn bearings or sloppy mounting bushes, perhaps one or more of your drive belts is/are too tight.
From your description/s I still do not know whether you have directed your stethoscope to the mid/lower portion of your engine - for abnormal resonance. This means not just the block, but the forward cover and the oil pan. Often overlooked is a worn/slacked oil pump chain and/or related parts. Yes, chain slap tends to be louder or more easily heard - at idle. A extremely remote possibility might be a loose/worn oil pump/oil pump pickup, in addition to a foreign object in the oil sump.
So I replaced the vibration damper and still have the knocking sound. The sound is coming from the top of the engine and near the middle to front of the engine so in the area of cylinder 1 & 2. Could it be injector because the timing of the knock aligns with the injector when I put the stethoscope to it?
I checked the sound at the bottom half of the stethoscope and the knocking was not that pronounced as it was at the top of the engine.
I have some thoughts for you…
And questions….
Did you replace the timing chain tensioner rail recently? How about the timing chain piston? Did you re-use the upper timing cover during an engine rebuild?
Do you have notes of what brands you bought?
Can you remove the valve cover and take a well lit high resolution picture of the timing chain tensioner rail with the timing piston exactly where they come together?
Thanks-
Sfdon
If you need an example- let me know.
I’m out on the boat today- pics tomorrow
And questions….
Thanks-
Sfdon
Thanks Don
Will have to take off the cover again.
I replaced the spring and end cylinder (where the end has a wide notch where the guide slots into). I bought those from bmw.
I haven’t done an engine rebuild or timing chain replacement.
Other thing to add is that the sound isn’t obvious upon startup or cold. When warmer then sound becomes louder and more prominent
Photos of timing chain tensioner
Well- I think we may have something to discuss.
Going in to shop to take pics for you….
something is not making sense.. a little help please.
your picture is hard to figure out.
please compare my pictures with your engine
last picture is yours….
