Stupid me - I have a borescope i should have used. Will take some more pics tonight when I get home
Thanks @BarryG. Is that the tension rail was loose or the rail guide on the other side of the engine?Hello Everyone
I have taken an m30 apart and found the pin & circlip that holds the chain rail loose.
It needs to be bled properly with oil per the manual in order for the hydraulic pressure to build and tension properlyMine isn’t very stiff at all.
Oil pressure guaranteed?
can you post a pic of top of head showing full position of oiler bar?
No oil pressure issues as far as I’m aware.
