Thanks Drew, I have a set of the short horns already. I have some more work to do before I go back to the side-draft carbs.
Yeah, as he noted above, Drew tried this and it didn't work.
Yes, and thanks for the picture. It does not look like these would work.View attachment 203923
Like this?
@halboyles : Looks great - does it also fit the later M30B35 from the E34/E32? I am planning to modify my M30B35 based B11/3 engine with VGS ITBs soon and will than have the same issue. Would love to solve it using your spacer. Can we manage shipment to good old Germany?We make the spacer to offset the thermostat housing. It retains the OEM look of the housing as it is not modified and it allows the use of even the later Weber Spanish DCOEs.
Perfect - will order soonYes, we ship internationally all the time.. As far as I know the coolant housing is about the same on all those cars.
Hi Alberto,Hello,
Do you supply the complete kit?
Regards,
Alberto
Got one in my parts collection and thought about a repro run. Depends a bit on what I will use for the ITBs that I am planning to install on my own car...I'd obviously be interested in the cold air intake box if one is available or more likely if anyone makes one.
While it looks cool, it definitely muffles the intake music, and I found it makes warm starts difficult because vapors get trapped in the box. You'll also need to rig up a CSi style mount for the filter box. I made one out of 1/4" aluminum plate that bolts to the old a/c muffler bolt holes. I usually run foam filters but occasionly put the rig back on for a change because I love having the complete setup.I'd obviously be interested in the cold air intake box if one is available or more likely if anyone makes one.
