It is in the way, just squeeze it out.
I agree with Chris: it will be in the way. Just lube it up with something like spray silicone and it will slip out of and back into the boot with a little persuading and wiggling. One of the easier steps in this ordeal.i presume that it might be best to leave it through the rubber piece + just disconnect it from the rubber hose below. thoughts?
In the video i posted in post #40 (with a bunch of explanations), you can see that install of the fuel door can be done with the rubber boot installed.Breiti:
It's great that you were able to install your fuel filler door so easily, while everyone else in this thread struggled to get it done. But tell me: did you do it with the black rubber boot in place?
Ah, I see i was unclear (probably)It will snap before it will bend.
You're right, the door can easily scratch new paint upon reinstallation. And your idea of taping some heavy cardboard on the panel in that area, and taping the edge of the door at the hinge end before you install it makes perfect sense. Except:When I reinstall this after paint, I plan to tape some heavy cardboard on the panel in that area, and tape the edge of the door at the hinge end before I install it. This is especially important when re-installing it with he boot in place, since that just makes the entire thing more challenging.
Actually the touching condition occurs during installation, when the hinge nuts are loose. Once they are tight it doesn’t touchI think that when you have a touching condition of the fuel door to the painted outside, that something is wrong.
E9's didn't leave the factory in that condition ; hence there must a reason why yours is doing that + it seems to me a solution awaiting to be discovered
Possibilities:
the reinforcement on the inside of the quarter panel (rear fender) with the 3 thread studs is bent a tad into the trunk area. Bend it back and check?
Or
I've never checked, but could the hinge wears out in such a way that the more frequent the door is used, the more it can rotate towards the painted body side while in the open position?
I was thinking of the Rhino paper ( like heavy masking paper) used to protect flooring during construction. Sturdy enough to not get gouged, but thin enough to workYou're right, the door can easily scratch new paint upon reinstallation. And your idea of taping some heavy cardboard on the panel in that area, and taping the edge of the door at the hinge end before you install it makes perfect sense. Except:
You will discover that there simply isn't enough room between the front edge of the door (when it is open) and the body ahead of the door opening to accommodate heavy padding. All I could get in there was a couple layers of tape on each of the body and door edge surfaces. That's why you need to fix that bi-stable hinge in its almost-open position with a bolt or screw+washer.
Right! Sorry if my message wasn't clear. I wasn't saying that my door hits the body every time I open it to fill the gas tank. Only upon installation.Actually the touching condition occurs during installation, when the hinge nuts are loose. Once they are tight it doesn’t touch
ScottAndrews said:I was thinking of the Rhino paper ( like heavy masking paper) used to protect flooring during construction. Sturdy enough to not get gouged, but thin enough to work
