Those look great. How will you be getting your vacuum source for your MC booster? What kind of carb linkage will you be using?
I'm going to try tapping directly into the barrels with a small brass fitting, and then piping that over to a larger manifold that feeds the booster. All hard lines connected with short hoses to avoid vibration.Those look great. How will you be getting your vacuum source for your MC booster? What kind of carb linkage will you be using?
Here are the fittings I am thinking of using. I'll daisy chan these along the tops of the manifolds and then feed that into a larger hose and check valve for the booster.Those look great. How will you be getting your vacuum source for your MC booster? What kind of carb linkage will you be using?
Looks amazing! I’ll try the TPU sometime this weekend just as a comparisonGot my updated AC drain funnel mold back. I'll cast some new funnels over the weekend. Pretty confident that this will work well.
Very happy with the quality of the print too!
