BMW 2800cs -> S38b36 project
About to start my E9 restoration project, also have a tight space in my garage, really like your moveable car lift, car you tell me were to get the jack element and will it lift the complete car.
Thanks Peter
It’s been a while since my last update, but again some progress the last few months.
I have my engine finally back, it is really an amazing engine to watch given its potential and how ‘fresh’ it now looks like!
Took a bit longer due to issues with the oil pump. Needed to source several and the oil stick didnt go through the hole because I use a e24 style oil pan. And because the rubber stick guide is not available anymore we made something ourselves.
Refurbished also some parts, like the rear axles, clutch slave cylinder, window lifters, heating unit/radiator and fan like Eric also described in his DIY post.
Latest thing is the steering column, the raptor 2k coating mentioned somewhere here on the forum I can really recommend! Very satisfied with the result :)
Does anyone recognize where these bushings belong to actually? Made a lot of pictures with disassembly but forgot these two. Was it for the gas pedal as on the photo or the clutch/brake pedals? Thx!
It is for the gas pedal, it fits into the booster mount with a plastic bushing on each side. When the bushings wear out the pedal gets sloppy and will squeak.
Thanks Chris, do we or you have a picture of that here on the forum? Did a check via the search option, found one with a guide on top of the pedal assembly were it looks like to have my bushings. But my pedal assembly does not have this welded on guide?
Look in the engine bay at the booster mount, it rotates the long arm that attaches to the horizontal rod to the bell crank and then to vertical to the carbs.
Progressing step by step. For the first time that I installed both engine en gearbox plus gear shift support. That is really a perfect line up I must say.
Need to shorten the gear rod or is there a direct fit from another model which I missed? This one I got with the gear support in the past. I red here somewhere that an e21 rod would fit/line up perfectly?
Now working on installing all components and make it all fit.
As you can see I want to use an e24/28 air filter box, need to modify it a bit. Metal, no plastic!
Progressing further, installed the interior heater housing and evaporator housing to see how the AC lines match up which are from an old AC installation and will be used as a reference only before installing new ones.
Was a bit surprised by the fact that the intermediate part on top of the evaporator housing was so much ‘blocked’ by the edge of the evaporator housing as you can see in the pictures. Should be normal I guess? And I still need to re upholster the edges of the intermediate part.
  • Like
Reactions: Dlc
