1970 2800CS restosortof
Gary, as it has already been established, this is an amazing build. I think you could bring back Restomod with this. (Actually I am so out of touch that I didn't know it was an "out" term).
I love your remote reservoirs and mount. I need to check exactly how far remote you can go with those as I am needing to put my Wilwood booster in my Transmission tunnel (it's a long story). I was planning to service it from under the car, but wonder if I can't get them just in front of the firewall.
Anyway, such nice work- one of my favorite threads.
The resos are pretty small. I bet you could find a spot. I am not sure that any distance is a problem as long as there are no high spots in the line. The master doesn't know how much line there is, it only sees it as more reso. They are small enough that you could probably even fit them in the right side well opposite of the wiper motor.
Thanks Gary- I was thinking that there may be a limit to the length of the extension (like sucking through a long straw), but I suppose that so long as the hose is running vertically this shouldn't be an issue. In that well opposite the wiper does sound perfect. Thanks again!
This weeks project was to remove the old school fuse box and wiring and integrate a new relay system and fuse system. This allowed me to meld the S38 EFI system into the 2800cs system and separate out the multiple circuits on 1 fuse scenario. There is still some cleaning up to do, but the car does fire off and all circuits work. New relays for low and high beam lighting, EFI, Main ign circuit, etc. Deleted load shedding relay and others.
Front and rear brakes done...all new lines front to back, fresh axle rebuilds, powdercoated arms and frame section, recoated bolts, etc.
I pulled the dash today for pad refinishing and wood refinishing and while I was in there am taking advantage of the access it provides to do some other work. First up was tig weld new oring fittings to the AC evaporator and make new hoses from the bulkhead fitting to the core. Second was to make a panel in the center dash to mount 2 3.5" coax speakers to fire through the OEM wood grill. The previous owner paid someone to originally put these in, but they were held to the wood with 1 screw and 2 zip ties. Now firmly mounted to ABS panel that is urethane glued in place. While the gauges are getting artwork done to raise redline to 7k and add numerals to the water temp and gas gauge to match the others, I will be making a new dash harness and radio and ac harnesses.
Finished the trunk trim for today, still need to shim up all 3 floor pieces so they sit correctly, but looking good so far. The front piece was complicated to cut around the battery tray and wiring, but I think it worked out well.
Gary,
This is Robert Olmedo the previous owner of the Professor. At first when you mentioned you were going to do update the car, I was skeptical, because I did so much work to the car to keep it original. All I can say now is HOLY COW!!! the car is AMAZING!!! Hope you enjoyed doing the work and maybe when I'm in San Clemente, CA, you will let me come by a see it.
Gary,
Didn’t realize this was the same car!
I’m in awe of you people that have the knowledge and skills to work on your own vehicles. I’m handy with home related work but just never had the courage to tackle vehicles. Hats off for amazing work.
