1972 3.0CSi - Riviera Blau Puzzle Project
Are the condition for the measurements done with the same conditions (what are the conditions on the BMW plot than would be good to ask).
I know from few sources E9 (as other cars w/o frame in 60's-70's) were flexible and thus sensitive to all the parts which are on the car. I heard stories about the cars which were perfectly aligned but have lost the alignment once the engine, suspension and glass/heavy parts were mounted.
Might it be it is somehow related to the way car should have been verified for proper dimensions but also some repair panels are not made from the steel type they have been in the factory (gauge, carbon content...).
From some reason BMW has not provided front and rear part divided into two dimensions (as they are hard to be measured). What is more, looking on the distance from the differential mount to rear suspension mounts dimensions are different - there is no symmetry there by factory. I would rather than measure total distance as provided on the chart rather than dividing it by symmetry line.
Have you been also checking symmetry on the outer shell to check if they are following suspension/floor assymetry? Than could in some cases confirm body deformation as they are all connected by welds.
I would not be surprised that at least some of the asymmetry came from rust and sills weaker structure combined with chassis fatigue due to age/condition of the car (still assuming no "situations" on the roads in the past).
It is the question how many people are making that measurements during restoration. It would be expected they will step-in and share their experience.
Hi guys,
Thanks again for the contribution and sharing the experiences!
Now that I draw the centerline and noticed that there was an offset on the rear support and front support, I went in the inside of the car to look for any potential bend or suspect area.
Here is what I found:
At the back of the car, the gap between the stiffener plate (that holds the back seat) and the tunnel is not existant on the right hand side, but is about 10mm on the left hand side. Based on a few pictures I could see on other members restoration projects, there should be a gap on both sides.
Picture of the right side of the stiffener plate and tunnel: No gap!
Picture of the left side of the stiffener plate and tunnel: 10mm gap
In the middle of the car, the right front seat support is flush with the tunnel. But the left front seat support is not flush and about +5mm away. We can see the welding quality is very different.
Right support and tunnel are perfectly flush on the right side:
Left support and tunnel show a gap of +5mm on the left side (see the shape of the welding).
Based on these additional investigation, I have the feeling that the tunnel was not centered (or already misshapen) while welded into place at the factory... back in 1972...
Would that make sense?
Yes, it make sense.
I join (later and in a other plant, not bmw) more than once the discussion, if an production fault is saleable or not.
If there is an gap under there carpet, cars would be sold as they are.
When they recognize it, they correct the fault and that's it.
My Mercedes has a repair at the roof skin definitely in the plant.
You won't believe how much body fault running out ro the customer...
All other means scraping it.
Nobody want that.
Breiti
I agree that what you find means that things in your car are non-symetric. But the tunnel "can't be" off-centre, as it's the first part laid down when the rest of the parts (sills, wheel arches, pillars etc) are being welded to it. The floor is 1 big pressing, the tunnel is not a seperate part.
For instance, the sills are just mated to the left and right edges of the floor, and thus the inner sill IS always equidistant from the tunnel's center. (unless the pressing of the floor is 5 mm larger on Left side and 5 mm smaller on right, which practically can't happen as it is a one piece steel pressing )You can confirm that by measuring, in the interior, from the side of the tunnel to the inside of the Sill. I think you will find that Left and right are within 1mm identical.
I'd rather think that the parts that are added to the floor+sills are off-center; for example the stiffener plate back seat: functionally only the top edge holds the rear seats, so when that is at the right height, it's function is fulfilled. The relative left right position isn't important, so seeing the 10 and 0mm gap to me wouldn't matter if I was the worker in the factory.
The seat supports also allow for some misalignment, as the the mounting points (the caged nuts) allow to slide the seats rails to their correct & parallel positions. After all, if the seat is 5 mm further to the center; who cares? As long as it freely slides front to back and the seat doesn't hit another vehicle component, it is functional.
I make this explanation as i think it means that although the pics you showed have non-symmetric elements, it doesn't mean (to me) that you've identified if (or why) your front or rear axle is mis aligned.
Biggest question to me (still) would be how the mounting points of the front and rear axle line up to the center of the car (=floor)
For this, i would mount 2 wooden sticks under the sills, running from left to right with the decorative trim panel unscrewed from the sill. One stick at the front, one stick at the back. Mark where the vertical plane of the inside sill falls onto the wooden stick. Then mark the middle of the wooden sticks.
From that, run a line (rope /laser) over it, to extend it to front and back so that you can verify the position of the axles and/or their respective mounting points.
Erik
I do agree with Erik and that leads me to the point in the past to check external body parts looking for non-symmetry there as sills and fender or pillars are critical and thus mounted to the floor panel at some points.
Hi there,
First, I thank you all for your very valuable response. I did not answer but took good note of your inputs.
I have not been able to respond quickly because I spend a lot of time taking measurements all over the car. This has been a very interesting (and tedious) process, but ultimately, I am now more confident in the situation and the way forward.
I initially used the laser pointer to point toward the measurement point. I finally abandoned this method to another one, which I feel more comfortable with. For each measurement point, I used the laser vertical line of the laser tool and marked a line on the floor (on masking tape). Using 2 lines allowed me to mark all the measurement points directly on the floor, draw lines in between, look for center lines and perpendicular lines, etc.
Assuming the floor is flat, the only caveat of this method is that you need to make sure which part of the car is leveled.
In my case, I started to make the measurements with the front support being fully aligned (front/back and left/right). With the front support aligned, I found that the whole body of the car was not leveled (e.g. door to door supports, front window frame, etc.). I finally aligned the back support area (left/right + front/back with the left front support) and took all the measurements again.
Here are a couple of pictures of the measurement approach, with the 2 laser lines pointing on the screw center point.
Below is a summary of the measurements
  • Overall measurements. The green doted lines have been drawn to verify how “square” the body was. Taking into consideration the measurement uncertainty, I believe the body is ok. However, the slight misalignment of the 2nd front support point is something I may have to look into.
Green doted line on the right:
Green doted line on the left:
  • Sill positioning compared to centerline (rear to front support). Difficult measurement as the sills are not perfectly straight. At least that gives an indication that the body is not completely offset.
Centerline:
Conclusion:
  • The whole body is in shape, except for the front right area. The front support is slightly off (1.5 to 2.0mm), but I am not sure that it is critical at that point.
  • The centerline based on the car body and the centerline based on the front and rear support centers are parallel but about 4mm off.
  • The right rail position is 5mm higher than the left rail. I’ll have to bring it back to its position.
  • The top of the right door post is off by 4mm. It may come back to position when I’ll work around the right rail. If not, I’ll help him a little bit! :cool:
Offset of the right front support when back supports and left support are leveled.
Please let me know if you have any questions or if you would like to get more details on the measurements.
Next step will be to build the structure to unbend the front right rail! Another fun part!
Hi guys,
Long time no talk! Time flies and the project moves slowly. Balancing work, family time and restoration is not an easy task.
I spend the 2nd half of the summer trying to put the right front rail into position. But all attempts showed minimal improvement, not to say they were unsuccessful. Overall, while the sub-frame is good enough to support the car, it is not stiff enough to apply a reliable constraint on the rail and bend it.
I did not expect this, but in the meantime, this is good to see that while a significant constraint is applied on the car, it bends but always comes back to its position.
Anyway, to avoid getting to much into frustration, I decided to start working on the rear and the left side. The purpose was to reinforce the differential support (typical), reshape a few areas and start dismantling the left sill.
Here below is a quick summary of what was done:
  • Reinforcement plate of the differential support:
    • I started the reinforcement by welding reinforcement plate inside the trunk. The shape is a bit funky, but the purpose was to limit the potential bending of the reinforcement plate and ensure welding points are spread all over the existing support and are on the wheel wells too.
    • I then made the second reinforcement plate on the outside of the car. Welding points were made in such a way that the 3 metal sheets were welded together (inside + original + outside).
    • The differential support reinforcement plate will be designed, bent, and welded in a next step, as I would like the car to be on the side to ease the work.
Scratching the soft sealant and sanding the area
Evaluating the bending pattern for the inner reinforcement plate:
Welding the traverse crack and drilling holes for the spot welding.
During and After welding:
Outer reinforcement plate:
If someone is interested in the support designs, I have them and can share the dimensions. Thanks everyone for the help in the thought process (with threads and PM).
  • Unbending of the spare wheel well. I’ll take care of the rusted parts once I’ll have a sand blaster. I'll share pictures once this area in completed.
  • Cutting and unwelding of the left sill. I’ll keep only the inner sill as it is overall in good shape. Only the front inner sill is significantly rusted. I’ll replace specifically this part.
Car under rotation! :)
Inner left seal and wheel well cut (only the welded area):
Things are moving foreward. Not as quickly as I wish, but still encouraging progress.
The greatest progress is maybe the color trial made by my daughter on the rear fender! :cool:
Hi guys,
View attachment 193175View attachment 193176
View attachment 193180View attachment 193181
View attachment 193182View attachment 193184
View attachment 193186View attachment 193187
Thanks for sharing your experience. Liked it to read.
Little by little, and try to get the right energy off the restoration.
Really great progress. It certainly is a ton of work when you do things correctly.
enjoyed the pictures and explanation very much.
keep it coming.
Hi there,
Long time with no news. Time flies and a lot of activities going on…
Following the installation of the strengthening plates to the traverse plate inside the trunk and the removal of the intermediate sill, I paused a little bit the work on the body. This was mostly due to missing tools. Weather constraints where not ideal to work on large parts (lot of rain).
I made a few metal stripping and media blasting but nothing major on the body repair itself. I send below a few pictures of the parts media blasted parts.
Door before and after stripping. The most tedious part of part preparation before media blasting is removing all the glues and debris from the door inside part.
Parts after media blasting: ceiling, trunk lid and door.
A few cracks and dents identified. Repaired areas with tin are also present.
Car rear and left areas after paint stripping
I spent most of the last few months blasting and painting mechanical parts. I will follow-up in the coming days with the progress on that side.
Have a great day everyone!
Excellent work. Very difficult to get all the body filler out with media blasting without warping the panels.
In this situation it is also an option to carry out chemical dipping and get it de rusted.
Example given
Yeah, I saw that too. It is a great process, but there is no company making such chemical dipping in my area.
The caveat is that the body has to be worked quickly to avoid rusting. There is a very interesting restauration project on a German forum, and difficulties to limit rust after chemical dipping is discussed.
The time I can spend on the car fluctuates a lot and I was not sure I could manage working on the body after such chemical process. This is why I preferred to use media blasting.
It is not an easy task indeed.
I noticed that the paint on the external side of the panels and body is much stronger than the one on the inside. If the car is damaged, putty may be present, which is a pain to remove with media blasting.
This is why I stripped the external paint. That made the blasting process much easier.
To avoid warping the panels, I blasted the media with a slight angle, always moving forward. As I needed to pause from time to time, I checked the work done and came back to the missed areas, if any.
Tedious process, but rewarding when you can see the parts are almost brand new.
There is literally no rush after this process. I had my 911 done by the guys in the video. The car has been in bare metal for 15 months. Doesn't even have flashbsurface rust on the panels. That last dip is a rust inhibitor and it really works. The only down side is that you see how bad your car really is all at one. And any closed sections need to be opened. On the 911 we had to cut off the perfect outer rockers as the heater hoses would have melted had we not removed them.
Hi all,
Long time without sharing any news. Some changes in my personal life led me to modify my approach for the body restauration. Basic lack of time + upcoming family tasks… so I contracted the body rework and painting to a local renown shop in my area. That allowed me to focus on restoring the other parts of the car, mostly the engine and mechanical parts for now.
Mechanical parts were all media blasted. I used 2 approaches for the media blasting:
  • A media blasting cabinet with cyclonic dust collection system for the small parts and delicate ones.
  • An outside blaster with a tarp protection for the larger parts.
The blasting cabinet is based on venturi suction. It is not the most efficient way to blast media, but the shape of the cabinet allows a natural flow of the media back to the bottom of the cabinet. Basically, the only limitation for continuous work is the power and capacity of the air compressor and the visibility in the cabinet. Even with the vacuum and cyclonic system, light dust is still floating around, so work must be stopped to verify the quality of the work.
The outside blaster is the best way to blast but the air consumption is significant and there is a need to recycle the media constantly. The compressor I used has a capacity of 100L and 3HP. It allowed me to work 2 to 3 minutes in a raw before the pressure decreases. This is not much… The time for the compressor to recover capacity was used to look at the work quality (some areas are not easy to blast) and sieving the media. The compressor remained inside the garage to limit the dust suction.
I used 2 bags of media, so there is a bunch of media stuck in the tarp corner, easing media collection before sifting it. It is a necessary task if you do not want to clog the blaster or overconsume bags of media.
Sorting the media is very basic using manual sieve.
If I had to do it again, I would buy a larger compressor… but I would also have to buy a larger garage.
Below are a few pictures
The set-ups:
Some of the parts after blasting:
For some reasons, some parts were very difficult (nearly impossible) to blast (pedals, pedal support, direction central bar) so I used the media blaster to grind the initial paint to improve adherence with the fresh one.
Some parts already painted, and some other one pending paint. Before painting, parts were protected with phosphating substance (this is why the unpainted parts are showing shades of grey).
Parts drying like sausages after two layers of satine epoxy paint…
