3D Printed elements of air conditioning/ventilation systems.
Good evening deQuincey.
Thank you.
I hope everything is going well with you. I haven’t seen you active for a while.
Best.
Lucas.
Hello.
The air conditioning project has been delivered.
The first clients are satisfied.
Time for a new challenge...
Apparently, there’s an issue with adapting the steering gear for the E9.
And I’m like: Hold my beer...
More info coming soon.
Below is a link to an animation showing how to install an air conditioning kit inside a car.
NOTE: The AI didn't make the final cut for production. It was dropped during the casting stage...
For now, it’s a silent film, but the band is finishing up the recordings. - Backing track loaded.
very fancy - wish the install would be as easy as the video :-)
question - will you include guidance on the holes in the tranny tunnel and in the fire wall as well in a future version?
I would ask Alex about the level of difficulty involved in the installation. He’s currently at that stage:
I don’t quite understand...
in the E9 world virtually nothing is easy... having doe a retrofit and played around w/ center console, faceplate, console sides a.s.o. I can confirm this takes time - independent of the kit used.
The AC system requires some holes in the tranny tunnel to fit the drainage plug and the screws. the hard lines require holes in the firewall. Would you intend to show these also in a future video? The instruction here starts where the holes are already in place. This is just an idea/suggestion - it is not intended to criticize this very nicely done video.
You are, of course, right. I know a thing or two about this myself, which is why we tried to make the assembly of the whole thing as simple as possible.
Yes, in the revised version, we will add a bulkhead with an opening for the refrigerant pipes.
Following your suggestion, we will also update the initial section to include mounting holes for the drainage funnel, as well as holes for the bolts used to secure the evaporator base.
  • Like
Reactions: Dlc
