I am replacing all seals of recently acquired 265 before install.
Why are you replacing that seal? Was it leaking?
I went with German Lemforder OEM. Was concerned about additional vibration with the polyurethane, and my tolerance for bouncing around in the car seems to have diminished somewhat over the years.
the z3 shifter is pretty short ... how is it on the coupe?
Hi Bill -- I have used polyurethane on some of the bushings in my e39 540, which in comparison to the e9 is an extremely stiff chassis. I do not want to try to stiffen up the e9 too much, primarily because the car itself is so flexible. In addition, I had thought the transmission of additional road vibration to the chassis would increase the stresses on the metal in our cars (Roads where I live, just outside Washington, DC are terrible). This is also a reason why I went with 15" instead of 16" tires.
That extra cushion makes life that much bearable when I hit potholes, plus I would have a little more protection for the rims. My main concern was the width. The tires rubbed on the fenders, hence damaging the tires, so I see that the previous owner rolled the lip upward so it's smoother and doesn't have clearance issues.If 225 x .45 = 101.25 and 205 x .50 = 102.5 then the difference is sidewall height is only 1.25mm, correct? Not much difference other than width.
I would have prefered to have 16's on it to be honest with you. But the 17´s don't look bad at all, besides the car is lowered, it favors it. There are those who put 18´s and higher, now that's an overdo in my opinion.Just my opinion, but I think 17s are too big for the styling of our cars. If I were in your shoes, I would go to a 16" wheel and tire and sell the 17" rims.
