Bert-Ola
Hi, I wonder if Paul Burke still are around and making special grind M30 camshafts.
If so how to get in contact with him.
/Bert-Ola Runeson
/Bert-Ola Runeson
I don´t think there is a market for new types of grinding on M30 cams.engine machine shops are a thing of the past
sad to say
too many new better products w/ better quality.
Did you try Mark Hutto at [email protected]
He was my contact when I bought Paul Burke cam and pistons
Thanks for the answers.
I´m looking into building an high rev M30 just to see what it takes.
Short stroke, big bore and as light parts as possible, aiming 8k rpm maybe more if possible.
I´ve got most of the parts already, just need to do some check on the crank.In order to run those rpm the motor should probably be designed from the start as a system and not a piece at a time.
What are the specs of the cams you have, do you think some may suit my purpose.Beware the high lift cams on flat top m90 pistons.
Evil lurks there.......
I have a few Paul Burke cams sitting in the shop.
Fair warning- his last editions were really problematic.
That is for me to seeAre stock parts really good for use above 8000rpm?
