I understand where the two horns are located but not how they are mounted, I have gone thru both the blue and white manuals and they do not show the mounting holes or the attitude can anyone provide this detail please?
From what I remember, the horn has a bracket around it and there is a bolt (13 mm I think) that fastens the bracket to the car. IIRC that bolt can be found when the access panel for the headlight is removed; it should be right there at the top. Someone please chime in if I am off.
From memory they are the rad mounting bracket for the wide (auto) radiatorI think I found the Driver side horn mounting location however the attached is a photo of the passenger side sheet metal. I don't know what the rectangular holes are for and the horn mounting is different than the driver side . With the large nut holding the mounting bracket there is only a few options to figure out. Any advice on the other rectangular holes?
Funny thing Chris is one of those horns got a bad cold and never recovered. It sounded like a sick cow.Gary, I’m surprised your coupe doesn’t have the snail shell style horn.
Mine are the original High Low beep!
