E3 Hood Liner
Dick Steinkamp
Bellingham, WA
As a follow up to my search for an E3 hood liner in this thread, I odered an E3 liner from the company Rob (@bavbob) had sent a pattern to...
It fit perfectly. Thanks, Rob, for sending them the pattern.
americium
Near Chico, CA
Looks like a nice solution. Is it the same pattern that fits the E9?
Whats the best adhesive to use To attach it to the hood?
Dick Steinkamp
Bellingham, WA
E3 and E9 are different. They didn't have a listing for the E3 liner so they had me order the E9 liner but specify that it would be for an E3.
The seller recommends 3M #80 or #90
Dick Steinkamp
Bellingham, WA
I couldn't think of a way to install the liners without taking the hood off. It is probably possible, but for me, removing the hood was the lesser of the evils.
I laid the liners in position and taped around them...
I installed each individually. Spray the hood, spray the liner, install. I used 3M #90
bavbob
Boston, Ma
Dick, they sent me three "BMW" decals for the large center part for my E9 as I was the 100th customer. I used the white one, sent the blue one to Drew, you are welcome to the red one if you wish. Here is it in blue on the E3, been almost 10 years now.... I used 3M #90
Dick Steinkamp
Bellingham, WA
Rob,
Thanks for the offer, but I'm kind of digging the minimalist look.
Anyway, you'll need it for your next E3/E9 project. Just make sure to make it a red one. ;)
bluecoupe30!
I will get to this, eventually, but I will not remove the hood. I spent several hours removing the original decayed, decomposed original foam a few years ago, and found I can reach all those areas if I take my anti inflammatory in the morning. ;) Yours really turned our well Dick. That tape idea is a good one. I think I am ordering from dealer as someone here posted that this is still available from BMW, for the E9.
I've had the factory foam and this version, and this is more durable. The downside is the need for separate adhesive which makes application more difficult, but still doable with care.
Dick Steinkamp
Bellingham, WA
In either case (peel off adhesive or 3M) you only get one shot at getting the liner piece aligned correctly. I couldn't figure out a way I would be comfortable with the hood on. The hood prop mechanism adds another degree of difficulty.
Mike, I can come up (if the border cross procedure isn't too daunting) and help. Two guys might make the "hood on" process doable.
The peeling works if it has that feature, I slice the backing paper horizontally in sections carefully with a razor so it can transition under the support bar easier and not stick where you don’t want it. These aftermarket ones need separate adhesive which makes for a more treacherous, challenging install.
bluecoupe30!
Yeah, that will work, Dick! I liked reading that the product you ordered is made of a more durable material, (Thanks Stevehose), because the original just crumbles when it reaches the end of its lifespan. I will let you know when that job gets scheduled, and we can see how the land border is working. Thanks!
bavbob
Boston, Ma
I spent a while aligning my E9 (not E3) hood and leaned that even marking the bolts to reproduce the exact fitment again does not work. So, I installed mine with the hood still on the car. Started at the top, used #90 (clean nozzle so you can control the spray) which gives you time to work. Took about 20 min, decal took another 20. Result below.
The E3 I did with the hood off...since it was already off.
BTW Dick our E3's are 72's and your hood torsion bar is shaped different than mine.......
Dick Steinkamp
Bellingham, WA
BTW Dick our E3's are 72's and your to hood torsion bar is shaped different than mine.......
The one that came with my car was broken. Mike (@bluecoupe30!) came up with a good one for me (Thanks again, Mike!). I don't know what year Mike's came off of. It did look the same as the one my car came with but I didn't examine it in detail for differences. It works just fine.
RealOEM (yes I know it's wrong more than it is right ;) ) shows one part number (41611804494) for all years and models 07/04/1968--09/21/2007. However, it does show this PN Supersedes 41611816213 (06/01/1973 — 10/01/2003).
I don't know why there was a different PN for the 73 and up cars since the original PN fits those cars. Maybe they changed suppliers and there was enough difference in the form to require a different PN? Then they went back to the original supplier for the service parts?
So it could be the one I got from Mike is from a 73 and up car and is PN 41611816213, and yours is 41611804494?
Post a picture of yours if the car is handy.
OK, you made me look it up. The parts book shows only one part, 41 61 1 804 494 as of March 1975 publication date. The 213 part (214 is right) is the left torsion spring and both left and right springs were superseded but RealOEM thinks it is the complete assembly.
bavbob
Boston, Ma
Dick, mine is in the photo above, the Riviera Blue E3. Strange as the bar is curved different but the arms are the same.
Dick Steinkamp
Bellingham, WA
On both of yours, the bend looks a little "softer". Is that what you mean?
If that is the case, could it be there were actually 2? And the parts book is wrong and RealOEM is right?
