E9 m30 3.0 si 1973 injection problem
Maciek98
Biarritz
Hello everyone
My name is Maciek and I am an apprentice in bmw in south of France.
I am working on e9 m30 3.0 si
My cylinder 2,4,6 injector don't have voltage on it via oscilloscope .
1,3,5 are good and are alimented .
I already check the continuity from injector to the computer who is new i changed the old one.
So the lines are good .
I don't understand why my alimentation to injectors is Okey but when I measure on oscilloscope 2,4,6 injectors they don't work.
We send injectors to bosh verification and I permuted recently to see if problem will migrate and after oscilloscope mesurment it s still the same 2,4,6 dont work.
We think it may bee some relay or something like that ...
If you have any suggestions I will be grateful.
Arde
Cupertino, CA
Welcome Maciek.
I would check continuity (like you did) and also resistance to ground, and resistance between each line, to make sure the lines are not shorted to ground or to each other. I would measure this without the computer plugged in and without the injectors connected.
Besides that SFDon here is the expert and can surely diagnose it without seeing it...
Maciek98
Biarritz
My control of injectors resistance was without
Welcome Maciek.
Resistence is ok between each line the same and the injectors were disconnected its have to be disconnected to get the resistance :/
Maciek98
Biarritz
Here some photos the igniter and bolt plugs are new
If you changed the computer and you tested the injectors- then its the wiring.
Check for short at wires to connectors at injectors
One of the positive wires is shorted to ground
It will still have continuity to the computer
Start by pulling the rubber boot back from 2,4,6 injector connectors.
options
injector no good- tested
computer no good - changed
ground missing for 2,4,6 - did you take off ground wires at intake?
is ground wire bad at intake?
short at harness- voltage goes to ground not to injector
Maciek98
Biarritz
We will start by changing those 2 boys and change connexions to continue the diagnosis when we stick the 2nd relay "1st is with starter red cable " the engine run well so we think it was the problem of this car
tferrer
San Francisco, CA
There is a great deal of corrosion on that relay. Clean up ALL the connections in the injector circuit. It may not be your issue but it surely can't help the situation. If all else fails, I'd get some eye of newt, an eagler feather, a vodoo manual and start learning how to cast spells....
Maciek98
Biarritz
We already start necromancy and sacrifice didn't helped yet
yeah tomorrow I will try to get them out the corrosion goes even inside the relay but the Cooper seams good we tried to clean them quickly but it doesn't help need to do it properly and take time now it's end of the work day
