Install the Distributor gear on the cam, Before the cam gear cover goes on make sure to apply a bit of silicone on the bottom corners otherwise oil leak and redo, I had to redo
Install Distributor the same way it was taken off ( Check the marks, rotor should match the mark on the distributor and Dist cap with number one cylinder wire pointing the same direction ).
Spark plugs and plug wires go in.
Exhaust Manifold, Intake manifold, Carbs and cooling system hooked up, Ready to start
Driven the car about 20 miles, runs great, have to adjust the valves again!
