at last connection instructions
finally i found a drawing that is not considering the need of a special distributor, i found it in a Bosch manual
1- DISTRIBUTOR WITHOUT POINTS: this is the conventional connection of a transistorized system, it considers the special distributor that is used in the CSI cars, the one without points, jean-luc used this one:
2- DISTRIBUTOR WITH POINTS: my case: this is the schematic for using the original distributor from the CS, only need to cut the cable that goes to the capacitor (you can keep it in place, for period correctness, but cut the cable that goes to the positive of the capacitor), you take the signal from the points in the distributor (marked as 1)
in this drawing i am representing a four pole cable because i am going to install this inside the car in a safe place to avoid heat and dust
