Nardi steering wheel hub
bluecs
Los Angeles
This Nardi measures approximately 14.5 inches (aporoximately 370mm) outer diameter.
To make it work on my 74cs, what will I need.
I want to make sure the signal lights turn off.
I believe it is set up for MBZ.
I've always only used OEM steering on cars.
Thanks in advance for your time.
I don’t think that hub will work, no brass horn contact ring, no where to attach turn signal cancelling ring. 14.5” or 37cm is a bit small for a coupe, CSL used 38cm. The finish looks very poor too. You can buy Nardi hubs probably on eBay but Nardi wasn’t OEM.
Incorrect hub. The good news is that it is worth the cost of a vintage replacement hub.
@Hans W. has original & repro BMW Nardi hubs
Would this one work?
Tom
All I thought needs to be done is remove and screw on the horn ring. My signal go off by a pice in the steering column.
Maybe yours is different.
Tom
I recommend buying a period nardi hub. Unlike Momo, Nardi uses the factory BMW horn ring with integrated signal cancellation lever.
Here is a good reference point:
