Lan-renewal of door trim, rubbers, clean and regrease of mechanisms,...
deQuincey
Quousque tandem...?
for the people interested, there is a solution planned for the mechanism spring support,
a drawing:
it is in production right now...
panel is prepared and finished with all the holes done:
tip: to make a better fit i opened the holes for the clips to 12mm instead of 11mm, if there is a deviation while marking the holes you will find very difficult to position 14 clips onto the door
deQuincey
Quousque tandem...?
the damned thing !
here you are this little ba***rd, it is only 450gramms ! but,...
this is the mechanism that holds the triangular window and rotates it open and close
the system consists of a cilindric part that is able to hold the triangular window frame rod, the holder has an evident M8 bolt, and a not so evident plate that is fixed by a clamp and a bolt (you can see the back of the clamp in the previous picture (a black tab only), and the bolt is in between the grease in the next pic),
the PO mechanic was not smart enough to figure out about the second fixing point so you can see how he destroyed the holder. it still works, but is a piece of s**t
you can guess there will be something else by the second, and smaller hole in the plate, it is evident for a skilled guy isn´t it ?
before dismantling anything, i marked all the positions to be able to replicate the assembly leter on: this is the lower fixing for the window rail
now the top fixing for the window rail:
the sliding part and the window plate:
the front lower sliding pad:
soak all these bolts on penetrating fluid a day or two before attempting to loose them, they are rusty and thus blocked ! so if you are not careful you can even break the glass
now it comes the tedious job of cleaning all these dirty bits !
rsporsche
Atlanta, GA
dQ, this area of your car must have been dirty, even though you got the parts dQ clean, their is dirt on those fingers and under the thumb nail ... i think this is a first.
all in all, another great post.
thanks!
deQuincey
Quousque tandem...?
thanks!
you r right
it was dirty as he**
and not a conventional dirty, but a nasty mixture of old grease, dust, sand, and dead insects
i can not clean my finger nails, no way
but soon i will finish with cleaning and i will start with the assembly...:-D
deQuincey
Quousque tandem...?
more
triang. window frame:
end of felt weatherstrip:
remove
copy end:
change triang window, remove rivets:
you remove the window taking it out by turning it slightly
place new rivets after introducing new window
cleaning and preparing bits for painting
i plan to reproduce the rubbers
deQuincey
Quousque tandem...?
door lock handle
finally i decided to remove everything of the door lock, inlcuding the handle, someone told me that it was a PITA, so i was reluctant to do this, but:
surface rust, removed and rust converter applied
mechanism, ready for cleaning:
clean door panel and new rubber stops:
cleaned and new bolts, nuts and washers:
deQuincey
Quousque tandem...?
apologies for my mistake
when i wrote about the door stop assembly position, i made a mistake, i was unsatisfied by the "feeling" of the door while opening and closing, so i investigated a bit, on the manuals and finally on a friends car, and the result is that the right position of the door stop is THIS !:
deQuincey
Quousque tandem...?
solving the axis problem
remember this ?
well, after some struggle trying to fix the damaged part i ended up making a new one with a different fixation approach:
but i need to prepare the surface to hold this part, the PO welding procedure damaged the area:
here you can see how the replacement part has been introduced after reopening the area, you can see the part prepared for the left side mechanism, and an special bolt and a washer that will act as fixing and retaining the part in its place:
the washer has been bent to provide a spring action:
i fixed the bolt using loctite medium strength glue
once fixed the mechanism works ok and is prepared to be assembled in the door
deQuincey
Quousque tandem...?
assembly almost done, some facts and tips
the assembly of all the elements is not difficult, but there are two important aspects,
first of all is the need of a sequence, some elements can be assembled, others can be compromised and impossible to introduce once other parts are mounted
second, is the inherent difficulty of the adjustment of all the elements to provide a correct movement and fit of the window
my experience says, that for a completely dissasembled door, the sequence is :
first is the outer handle and its mechanism, then is the door lock mechanism, then the door lock itself, following this sequence it is straight forward, but one last issue, the final adjustment of the outer handle must be done at the end of this block of parts
(do not assembly now the inner handle mechanism, this IMHO is the last mech to be assembled in the whole door)
when this is finished, the next part is the triangular vent window, the complete frame, place it in its position , but do not tighten the nuts and bolts
then the window glass itself, but to introduce it you will have to remove the big support that move along the rear guide,
then introduce the rear guide, and with this part in position, introduce and fix the above mentioned support,
now introduce the vent window mechanism from under
before any window adjustment, introduce the window lift mechanism, the adjustment will be influenced by the whole system
in my experience, the adjustment is too complicate, not only you will have to compensate the paralelism of the guides, but the position of the mentioned big support within the window glass is also an aspect to be considered
it is also critical the position of the lower supports of the guides, these two points, one in the front and the other in the rear are the responsibles for the top of the window to move inwards or outwards
this adjustment is critical for a good closing of the front and rear windows one against the other, but is critical for the closure of the triangular and front window against the door top frame too
i am still preparing an alternative rubber part for the NLA one in the weatherstrip, so my experience finishes here, but i assume that now i will have to assembly the outer weatherstrip, then the inner one that carries the wood trim part too
then the door foil (this will not be done for some weeks while testing that all works correctly)
then the door panel, and then the arm support, the door handle, the window lifter handle, the ashtray
....und das ist alles !
tmason
Reno,Nv
Holy crap Batman, deQuincey you are making think about leaving the windows down so I can climb in and out without wearing out my doors parts! Another good lesson on what to do,Thanks.
