Good idea. Will do! Thanks!
Blue Bosch Coils are for non contact breaking points systems (working with ignition module).
Your old ballast resister show that you have contact breaking point system, so you should look for part
12131357295
But Blue coil also need resistorI'll just not use my ballast resistor and use this blue one w/the internal resistor.
Ok, i can even agree with this theory, but why all of manuals (i have & blue books) always shows ignition system without contacts with 2x resistors 0,4 & 0,6 ohm (for other cars resistance might be slightly different) as anyway they used different (blue) ignition coil?Bosch "Black" coil (original coil on our cars) used a .8 ohm ballast. "Blue" is internally resisited, no ballast needed. "Red" has hotter spark, requires 1.8 ohm ballast. Not unusual for ballast to be warm as it is exchanging heat for voltage reduction but not smokin' hot!
Ok, it make sense. If you have contact breaker points - use coil with build-in resistor & you don't need any additional external.Steve is correct. Even through 1975 at least BMW used resistors (in the wire itself) on the 2002s, no blue coils were used, they came along later.
I think e9 didn't have it at all (no info in ETK), but e3 have it in later hi-end 3.0Si & 3.3Li. I think in e9 it was only users upgrade, so some cars could have it.When did the e9 have non-breaker points, 74-75 or?
But if you enter full Bosch 003 number in google you will see that this is Blue one, s0 .... isn't it resisted?It says never install the Bosch 003 when you have points, meaning it isn't resisted.
So, i assume with every new Blue Bosch coil should be then information what type of resistor was used inside.The new Blue Coil isn't the same as the original Blue Coil I think.
Why does dp say no external ballast is needed??
