Smokin' hot ballast resistor
Wladek
Gdansk, POLAND
Because it is not. But, if you want, you "can" go ahead and buy another ballast resistor,
and even install it, but if you do, it will weaken your spark, which you don't want.
It will also more than double the cost out of pocket for your fix, which I assume you also don't want...
if you ordered the blue coil from Amazon you should have it before the weekend. Git 'er done.
-30-
Will blue coil do the same job in system without breakers - no external double resistor will be needed?
