Bob,
that was a helpful piece of information - when you apply the formulas on summit video - here's what comes up for maximum torque RPM based on a given primary tube diameter. Remember, this is peak torque RPM, HP moves beyond that.
1 3/8" 1 1/2" 1 5/8"
2.8L 3933 4779 5667
3.0L 3671 4460 5290
3.5L 3147 3823 4533
To further what that says, if you want a flatter torque curve (more low end) approaching the peak torque RPM ... use a longer primary tube. if you go with a shorter primary tube, then you will extend the flatter torque curve to the higher RPM side of the curve (with less low end torque).
