jamesw
Have any of you seen the white coupe w/ a turbocharged M30ish engine that is for sale on Ebay now? I wonder how he built his.
Cheers
James
Cheers
James
The m106 is quite different from m102
Different compression, boost, operating system.
Early Alpina and BMW turbo systems offered low compression and high boost.
The 4hp22 eh version uses an extra large bell housing for the big P1 torque converter- I would wonder whether it would fit in the coupe.
Keep in mind the m106 developed max torque at only 2200 rpm and managed 144 mph in
3 gear. In 4th gear at 80 mph the engine was only running at 2000 rpm so it was hard to wear out.
Hi: I was looking for info on Turbo set up in my 1972 3.0 CSI. I think it has all the early 7451 turbo components with the Djet fuel injection. Id the FI in your picture Djet? I have 3.5 Engine but I have not figured out what head I have yet!Pics of M106 going into Jon Iversons Turkis coupe
I am re-reading the Rotrex info- that has to be one of the least informative web sites around.
Good news is that Active Autowerkes is a dealer & they are in my back yard.
Will give them a call tomorrow.
The bottom line is that you simply can't pull enough power from your electrical system to be able to stuff enough air into the intake to make a difference. The only energy source that is powerful enough is the engine via a belt or the exhaust gas via a turbine.
Never say never Ian. You should watch this:
