e9coupe.com
Very interesting.Best solution me thinks:
Thank you for the specifics and the graphic. I am still amazed that there are only 6 fuses on these cars. I think I'll add a separate power hub like the Denali Power Hub 2 so adding accessories will be easier and safer.You could simply attached a wire to this terminal, and you would have fused power to your gauges.
Yes, a very good idea!I tapped on into the rheostat for the gauge bulbs so they come on with the lights and dim
Six? Ten.Thank you for the specifics and the graphic. I am still amazed that there are only 6 fuses on these cars. I think I'll add a separate power hub like the Denali Power Hub 2 so adding accessories will be easier and safer.
