What are these wires?
Dan Wood
Newnan, Georgia
These wires are hanging down between the light switch and the steering column and I haven't been able to figure out what they are for. I am not missing any wires on the light switch. I have gone thru the schematics several times but just can't figure out what is missing. Hope someone out there can help. Perhaps a relay? Thanks
Do you still have an ignition key buzzer and dashboard warning light? They aren't in the diagrams but that is my guess.
Dan Wood
Newnan, Georgia
Chris
The buzzer (works but weak) is near the ignition switch in the column and the wires are not long enough to reach the gauges.
I confirmed the brown is grounded and there is only 0.08 VDC to the pair of wires with red stripe with ignition on and no power to the single wire.
Power off from ground to the pair with strips is 3.2 ohms. Something else powers these wires. I may need to wait to be able to power everything on to see what happens.
Thx,
Dan
Dan Wood
Newnan, Georgia
Dan/Chris- could they be for optional fog lamps/driving lights?? maybe on US versions only?
Peter
Could be an option for fog lights. There is a recess (uncut) in the underdash for another switch (similar to hazard or rear defog) that could line up with the wires.
Thanks,
Dan
Thomas76
Michigan, USA
Just looked on my cheat sheet for wire colors.
Gray w/red has a few locations
1. Fuse box to light switch
2. Rear parking lights and license plate
3. Voltage splitter for automatic trans position indicator
Looks like you have manual trans, but my guess is you could have harness with automatic extras?
Dan Wood
Newnan, Georgia
Thomas
I do have a manual trans. Wiring for auto trans is a strong possibility.
I need to find the position indicator on the schematic to confirm.
Thanks,
Dan
Connection 32a on a usa car which goes to nothing. There is no 32 switch in USA - only euro.
its in both lighting schematics.
Dan Wood
Newnan, Georgia
Here is another mystery for the experts as I start cleaning up the engine bay. This bracket is on the firewall above the engine and there are 2 wires (Green and Brown) that most probably attached to whatever was mounted. I have gone through the schematics and pics on BAT.
Any ideas?
Thanks,
Dan
Thomas76
Michigan, USA
Maybe carb stuff, extra relays can exist for things like electric choke. Maybe emissions based relays that came later cars?
US coupes had metal dash pots there receiving a signal from the speed relay below the coil and they controlled vacuum for emissions controls like the dash pot on the accelerator rod to slow return of the accelerator when letting off on the pedal. Early coupes had one or two, 73 and later had three. They can be removed along with the speed relay and the black/red wires by the coil.
Dan Wood
Newnan, Georgia
Thanks Chris
I figured it was something I didn't need.
