Gary,
did you talk to korman or stahl?
I think it was Jere Stahl's wife.
Gary,
He does grind his own cams, so if you have a particular spec in mind, he may be able to accommodate you.The N21 camshaft would be an excellent upgrade. It retains the same idle characteristics and basic torque/horsepower curve, but increases rear wheel torque from 190 ft./lbs.@3800 rpm to 236 ft./lbs.@3800 rpm. Rear wheel horsepower is increased from 171@5800 rpm to 218@5800 rpm. The M30 B35 cylinder head already has dual valve springs, however, the seated and open pressures should be checked.
