Lan-renewal of door trim, rubbers, clean and regrease of mechanisms,...
more
this is the NLA rubber part, and the raw material to produce a solution
Holy crap Batman, deQuincey you are making think about leaving the windows down so I can climb in and out without wearing out my doors parts! Another good lesson on what to do,Thanks.
I insist in placing a lot of pictures cos i find myself pictures very useful to check, compare, and to avoid mistakes
I have found this job really painfull, with a feeling of starting something that it was not very clear that i would have the ability to xomplete
I will not start with the left door by now... !-)
a question
great as always dq - my question is, was it worth it? does the door close better now and require less 'shutting force' (aka slamming)? handle and lock movement much improved? window movement/speed? etc.
hi, a big yes !
it was worth every drop of sweat, every dirt in my nails, and every little cut in my fingers,...absolutely
- my door stop was broken, now it works
- the door closed badly, you had to try twice or thrice until you apply the right force, now you have the bmw-plonck correct sound
- the window was badly adjusted to the door frame and to the rear window, sound was comming inside through those gaps
- the door lock mechanism was blocked, i was unable to close the door with the lock, i had to lock it from inside, now the lock rotates smoothly and does its work with precission
- the window needed too much effort to go up and down, as it moved not aligned to the frames, now is smooth as skiing in perfect snow
- the weatherstrips were cracked, the felt was in bad condition,...
- the door trim looked awful, bended and curved because the base meterial was deteriorated due to the action of humidity
- some superficial rust was found in the door panels, rust had been treated and blocked
- some bolts were loose, and their threads damaged or even destroyed, now all new bolts, washers and nuts
- glass support rubbers were cracked, now new rubbers are flexible and soft providing a good performance
and last but not least the fit is perfect
the question was not if it was worth, the question was why the heck i have waited so much time to do it...;-)
Door Card Cleaning
DQ,
Following your guidance my mechanic and I are splitting the duties you've outlined, albeit not exactly 50/50. I am responsible for cleaning the door cards (and possibly replacing the cardboard stock if need be) and he is handling the rest. I believe I have seen another thread for the right cardboard stock to buy but what is the best way to clean the actual vinyl? I was assuming a toothbrush and some mildly soapy water but that might get everything too wet if I don't decide to replace the board. Any tips to avoid (or absolutely do) to the vinyl?
well you are right, water in your card will be a problem, avoid using it unless you take extreme precautions to avoid water entering the board side, the problem is that you have a lot of holes so this seems not really doable
if you are not going to remove the board i would use a Vynil care product, like AUTO GLYM. this will suppose the use of much less liquid and thus a easier recovery to dry the board
I know there are several threads on door panel restoration but I have not found a consensus on board material. Is there a specific weight (thinking cardboard) or density and/or thickness? I would like to tackle this over the weekend. Please feel free to talk me out of this if there are easy options for just buying and shipping them to the east coast.
the only single advise i will give you is this one: buy the same thickness ! the pocket nuts will be impossible to fix if it is thicker than the original, and you will find very difficult to intorduce it under the wood line
i do not think that it would be very important to use one type or other, pressed cardboard, i do not think that you will find many different types
imho weight, no problem, at least it has to be easy to put staples on it, i would recommend to paint it with latex or similar to avoid water and moisture going inside
it does not need to be very strong, dense or stiff
i propose that you use an intermediate layer of textile or a very thin foam for a better touch feeling
Loose springs - Window repair?
deQuincey,
First, thank you for your detailed explanations of E9 sub-system repair and restoration. Great work.
I've been working to restore my door windows and wing windows - after cleaning I came across 2 small springs in my parts washer.
Any suggestion - window track maybe? Wing windows maybe?
Thanks,
Tom P
deQuincey,
Thanks,
Tom P
as far as i can tell i have never seen those springs during my works in the car
sorry
Do they fit behind the round pieces that hold the regulator arms into the window frames? I recall those being spring loaded.
deQuincy,
Thanks for that very informative presentation. I just saw this today, after pulling apart my rear window assembly on a whim last night.
I had not planned on fabricating parts today, was just going to pick some new stuff up (Yep E9 Newbie),
What was I thinking? I have the experience and certainly the tools to do it, but was a bit disturbed to see what you had to do.
I really wanted the felts but they seem to be non-existant at this time. in Temecula, CA at least.
My neighbor is kind of an ass, and I bet I could adapt the pasrts of his new Acura to fit :).
Thanks again, big help for the mental prep at least!
Robert
deQuincy,
Robert
rob,
there is another thread on the rear windows, you must look at it !
directions:
click on my name
go to see public profile
click on statistics
click on find all threads
enter in DIY paradise:razz:
it is in page number 3, " rear windows,...."
Guys,
I'm in the process of stripping down my door so that there is access to the outer edge of the top of the door, under the chrome strip. I lifted the trim up to replace the rubber seal and found some rust along that top edge that needs some attention. I have followed deQ's excellent step by steps but am stumped by the internal mechanisms removal. Do I need to remove the window glass and it's runners ect before the quarter light window frame or the other way around?
Anyone out there who has stripped their door right back?
Thanks.
John
you need to make room for removing the triangle, so at least you have to loosen the window glass first, and this implies loosening the rear window slider
basically yes, otherwise the tensión of the window will not allow you to remove it
if you read this thread carefully there is a text that explains the sequence, it is only my opinión, but at least i can confirm that it Works this way
regards
Quick question - outer chrome door trim
Thanks DeQuincey - well done and invaluable documentation.
2 questions...
(1) I believe I have the clips inserted correctly. They just slide over the metal at provided gaps in the felt backing strip? Then I suppose they create a friction fit against door top?
(2) The NLA rubber that's shown in my photo just below the chrome trim affixes to front edge of trim - guessing with some spray adhesive. But, what about the second one down? It's heavier/ stiffer rubber and I have replacement new rubber for it. Anyone know where that piece goes?
Thanks!
