Still sorting through the various loose wire, solenoid connections, etc related to a bogus ignition switch.
Newest problem is my ballast resistor is heating up to the point where it is smoking, and this after only 30 seconds or so of run time.
I tried a second ballast resistor and experienced the same red-hot results.
Any clues what may be the cause?
Also, does the igntion coil function only to start the car, or would a sub-par coil result in a very rough engine??
Is the coil a black and white either it works or it doesn't type of apparatus, or will it decline over time (like my backhand, jump shot and electrical skills?)
