4310316 begins
Use a e32 harness out of a 735i.
follow the row 52 search. When a fresh 735i gets dropped- go grab the harness.
Or pay a picker to get it for you.
don’t go to the one in Newark - I already got it.
so ill get the 7 one -
so with that ill need what ecu?
so do i just wire it up and then ill start?
BMW E12 530i 528i complete engine harness w/sub harness 530i 528i E9 E3 UNCUT​
will this work
Engine Computer/Module Ecu/Ecm/Pcm 2009 X5 Sku#3041655​
12147568900, 12147572058, 1214757655
maybe ill just use a 90 m5 harness
gosh im lost on how to get this running
ill just the darn thing and be done with it!
I’m a bit confused on the proposed solution. Is the goal to use the M5 harness, or the M5 ECU? Do you think the factory ECU will support your custom high compression motor? I honestly don’t know.
MegaSquirt PNP BMW 1988-1992 735 e32 w/ m30 standalone system plug and play ECU​
don should i buy this to put
in my car
Item information​
Condition:
New
Here’s the ECU I have.
Bosch 0 261 200 150
And wire harness and other parts
Nope
150 ecu is one year only Motronic 1.1
Edit- 1 1/2 year.
735i/iL E32 M30/B35 86-88 0 261 200 150 Bosch Motronic M1.1
shogun's Avatar
shogun
shogun is offline
shade tree mechanicModerator
Join DateJan 2005LocationJapanPosts50,415My Cars11/88 E32 750iL+98 E36M3
179 Motronic will fit instead of the older M1.1 150, and vice versa. But the chips are not interchangeable, that means a 150 chip will not work in a M1.3 179 Motronic and a 178/9 chip will not work in the older M1.1 150 Motronic. Tested and failed, someone from Europe bought from me a 179 chip and installed it in a 150 Motronic (as he did not know the differences). Nothing damaged, but the car did not start .I know that from the E32 especially in Europe where the older E32 were still equipped with the 1.1 150. I have tuning chips for the 150 and the 179 and most owners of E32 with M30 buy them especially from the German 7-forum , but some of them buy my 179 chip and buy a used 179 Motronic and install it instead of the old 150. In Europe the E32 was sold from autumn 1986 with the older 150 Motronic and later that changed to 179 1.3
The main differences between 1.1 and 1.3 I posted here http://www.bimmerforums.com/forum/sh...ic-1-1-1-3-BMW
s, Bosch p/n etc​
Courtesy of a tech article of pelican parts http://www.pelicanparts.com/BMW/tech...DME-Repair.htm
In case of E32 we have there (based on U.S. specs/years):
735i/iL E32 M30/B35 (211hp) 89-92 0 261 200 179 Bosch Motronic M1.3
740i/iL E32 M60/B40 9/92-4/94 0 261 200 404 Bosch Motronic M3.3
