1974 3.0 CS With M88 Engine (3.5 CSM)
Patton
Atlanta GA
B-Quiet installed, again.
RP
Patton
Atlanta GA
Fiberglass bumper sag ( not in line with break on the body), rookie mistake.
Remove bumper, enlarge holes in body, reinstall.
RP
Erik
NorCal, CA
Always thought the wiper washer nozzle delete was a desirable clean-up and your hood looks great without. Did you replace with older-style nozzles?
Patton
Atlanta GA
Erik , sharp eye. There are 73 other holes that were filled in/welded.
Thank you for the compliment. It does look much sleeker, if I do say so.
I didn't bother with cleaning nozzles. Once complete , this car will never see the rain.
RP
Patton
Atlanta GA
Dave, redefining “boat tail.”
Got a picture of the “color clip” idea? I’ll try to use it.
Thanks, RP
Patton
Atlanta GA
tferrer, too late now for the wood.
The metal plate turned out to be a very simple/easy solution.
RP
dave v. in nc
North Carolina, USA
I think that they are NLA..I'll check, not sure that I have an extra. Figured you might be able to fab one from PVC or similar? Maybe soften the edges and then heat bend to match contour? Just thought it would be a nice finishing touch.
Patton
Atlanta GA
If you come across a lead, let me know.
It is now on the “ punch list“ of things to do.
Thanks!
RP
