hope you find something without too much damage, or better yet - NO damage
It’s not the depth thats a problem its the angle down from the spark plug hole. Its easier to move the magnet and camera around when it’s at the bottom of piston travel. But when I feed the magnet down the passageway of the head, through the plug hole, the angle down to the passenger side of the cylinder is proving difficult. I did turn the engine over in each cylinder while looking at the camera and saw nothing in there moving around. Am working on a vacuum attachment now. Will also feed the camera down the intake manifolds later. I’m wondering if the missing nuts on the carb inlets are a head-fake and I have something else going on entirely.Can the magnet reach if you rotate the crank until you get closer to TDC? Even if you use a vacuum you will want it close
to the omit hole. Sorry if captain obvious.
Thanks, otherwise @sfdon is going to be surfing on the west coast of FL soonhope you find something without too much damage, or better yet - NO damage
All rockers, rocker pads, and nuts in tact. No noise from the distributor. Oil pump chain/sprocket looks in place and moves smoothly when cranked, and I get lots of oil coming out of the spray bar.Andrew's point about checking the pan is a good one.
Is the noise still present if you start the car?
For the front of the engine, if the rockers seem good, are you running the distributor? Are all the bolts present and torqued on the cam gear? I have also heard about the oil pump securing bolts coming undone, as well as the oil pump sprocket being loose, even though it's got a reverse thread on the securing nut. (as I recall)
I recall you built a rotisserie for your E9. With that one could put the car upside down and rely on gravity...Andrew's point about checking the pan is a good one.
Yes, but the M30 the cam gear and chain throws oil all over the place. I made a shield once to film my oil sprayer bar but threw it out because it was a one use deal. I may make a better one this time that fits better. Good idea.Piston looks more like a 2” scrape which would be hard to do with a loose bolt.
Can you do this or bad idea? Note the towel keeping the oil away from the exhaust. Not that the exhaust would be that hot to start.
e9coupe.com
Doesn't sound like something that would be loose flopping around. I think a video is the next step. Let me get my popcorn first...The sound is rhythmic and doesn’t sound like a pinball machine.
Have that good to go!If and when you do start it, get an engine stethoscope ready...
I will do this for the exhaust valves tomorrow, I checked all the intake valves, they move freely and look like this:Can u position the bore scope so it can see the valves? How about turning the eng over by hand so that one intake valve is wide open and have a look down the carbs and intake at the intake valve seat at least a bit of it I don't see anything on the top of the piston that is hitting something, nothing embedded into the top of the piston.
May sound crazy but if the noise is gone, try banging the exhaust to see if something has gone rigt thru and is now sitting in the bottom of the exhaust. I did see a 6 mm nut go in thru the intake, banged around just a little and went out thru the exhaust!!
Thanks, Rick
