72 3.0 CS 2240344 Restoration
This is a partial repost from the rocker drain holes thread.
I took a few more photos of my rear rocker assembly, and sorted out what is what in the tangled rusty mess. The right rear rocker had a small rust bubble, that I found once I took the crusty rocker trim covers off. That was nearly 20 years ago, before life and jobs, and multiple other home and boat projects got in the way of car restoration projects.
Here is what I found back then:
I decided to cut into this to see just how bad it was. At the time I did not really understand the structure of the car, and specifically the complex structure right around the A, B, and C pillars.
The rocker has three primary components: Inner rocker (which the floor is attached to on the sides), what I call the "zig zag beam" (which is a flat piece with perforations and zig zag indentations), and the outer rocker cover (this is itself covered up by the rear quarter panel in the back, and the fender up front). Together these three parts form a tubular beam that runs from the back of the front wheel well, to the front of the rear wheel well. At the pillars there are pieces that attach to the zig zag beam to form the vertical elements of the car (front door pillars, door latch pillars and rear wheel arches (which eventually become the C-pillars). .
Here is what was under this rusty spot at the back end of the right side rocker (some of the really crusty stuff has been removed in this pic). Since it is a bit hard to tell what you are looking at, I have labeled the components.
Here is a better view from the bottom looking upwards:
Fortunately the zig zag beam and the c-pillar are actually solid, just rusty on the surface. The rocker cover is another story.. nearly totally gone at this area. It gets stronger as you move forward. You can also see the culprit in this show, which is the drain tube from the C-Pillar roundel vent. I am surprised how much water comes in there, but I guess it is from road mist blowing around the car in the rain, and maybe from overly aggressive washing. At any rate, the hose drains into this area, which is supposed to drain out of small weep holes in the bottom of the rocker assembly. I have not checked these yet, abut I suspect they are clogged.
I also found a surprising amount of dirt and grit, mixed with rust flakes lodged in crevices in this area. I am not totally certain how this gets in there, but it is possible that some of it comes in the drain tube, and some falls down the hollow c-pillar. 50 years is a long time to accumulate a few tablespoons of grit. I think I had at least 3/8 inch of similar grit up in the "shelf" in the front wheel well.
Fortunately for me, I think I can cut the quarter panel back below the lip where the rocker trim cover goes, so the repair should not be visible. It will involve removing the lower 4-5 inches of the quarter panel from the door to the rear wheel well, removing the rusted rocker cover, cleaning the beam and everything else I find in there, treating everything with POR 15, and then welding in a new section of rocker cover (shown in a post above), and then welding on a replacement section of the quarter panel.
The other side is not as bad from the outside, but given how bad this side was, I'll at least open that side up, and probably do a similar repair.
Been discussing floor repairs with @Mike Pelly (super nice guy!), and have ordered a set of his floor pans. I only need to replace the front floors.
The driver's side should be a pretty simple cut and paste job, since the rust is mostly located in the recess in the middle of the floor. The passenger side is much worse. Mike suggested that the location of the inner corner close to the exhaust down tubes tends to heat and cool the floor metal, accelerating its decay.
Here is a shot of the passenger floor with the approximate outline of the section of pan I'll be using (solid yellow line). The dotted line shows the part I'll have to fabricate, probably from the unused portion(s) of the floor pan(s).
I'll need to remove the heater and the trans tunnel insulation, and brave the import tariffs before diving into this, so it will be a few weeks before I fire up the welder..
If the a/c drain is plugged which is very common the water that collects can slosh around and spill into that area as well. I think that was the case in my first coupe as the floor pans were good.
Yeah, Mike P suggested it was a combination of AC condensation and heat that was the real culprit.
First issue is the exterior finish (clay? carved wood? ) the second is the abrupt change in the flow axis from the throttle body to the manifold...
I'm no authority on intake manifold design, but the angle change between the throttle body and manifold doesn't trouble me much. Note that the mounting angle allows the injector axes to be aligned with the manifolds and head ports. While there might be some resistance as the air is forced to turn the corner, I'm guessing that the resulting hp loss would be negligible for anything short of an all-out competition application. And maybe the throttle bodies need to be aligned horizontally for the air filter to fit in the available space.
The manifolds' exterior finish does look stone age; I wonder how well the inner bores are finished?
Yeah, I'm no authority either... From a physics perspective, I would think the abrupt angle change would cause turbulence, which might be good from a mixture uniformity perspective, but a smoother flow would probably cause better intake efficiency (less drag) in the same way that porting and polishing helps with that last little bit of performance. In any case, an old engineering principle seems apt here. If it is beautiful, then it probably also works well. If it is ugly, then it probably doesn't (I just made that up)...
So here is the very first 3D prototype manifold. This is a 30 degree unit made from my initial model, which I messed up, so the primary flow tubes did not render as tubes in the print (I knew this going in). I have since modified the design to a 25 degree bend, which gives a slight tilt toward the engine for the carbs (recommended by Weber), and also fixed the rendering issue.
I am very impressed with the surface quality of these parts! I had them printed by a prototyping company called Xometry. This one was printed in the US and cost about $50. The 25 degree units are in print now. The off-shore print cost for those was $70 for three units. Can't wait to see those!
OK, first pass at the carb trumpet elbows. These are 85 degree bends with a bell mouth trumpet. The idea is that an air filter will sit atop the bell flange, and with the carbs tilted 5 degrees, the 85 degree bend will place the air filter horizontal.
This was a fun exercise in 3D modeling. I'll check the dimensions, and add some webbing for strength, and then print a set of these too...
OK, Back to rust work!
Spent a bit of time cutting out more of the rear quarter panel from the rear wheel well to the door. I have not started yet on the spot welds along the bottom, but I'll get to those when my spot weld drill arrives in a day or so.
This effort exposed some good and bad news. The good news is that, as expected, most of the upper part of the rocker cover piece is OK. The bad news is that it is rustier down below for more of a distance than I was expecting. The metal at the lower part is actually relatively solid, but there are some small rust perforations from the back side, so I plan to remove the lower half over the entire length from the door to the wheel well. That will also allow me to take a hard look at the intermediate beam and the lower B-pillar. I can feel the B-pillar through a couple of the rust holes, and it feels solid. Certainly not crusty...
I am hopeful that I can keep the outer panel cutting below the rocker trim line. That will greatly simplify life when we get to leveling the outer surface...
Onward!!
The real fun begins!
Got the rest of the lower section of the rocker cover off. The good news is that the B pillar is solid. It has rust on the surface, but it is structurally sound. I did notice that there are a lot of rust flakes that collect at the bottom of the rocker, between the various pieces that come together at the lower seam. I am reluctant to just assume that the forward section of rocker (under the door) is clean, since the surface rust seems to be pretty pervasive, and the idea of rusty crud sitting in the bottom of the rocker forever is not pleasant.
So, since I have the full rocker cover panel. I think I'll remove the lower 2-3 inches of it all the way forward, all below the top edge of where the rocker trim goes. Then I can really clean the entire assembly, get all the rusty gunk out, rust convert what I can't reach, and paint everything before putting the removed portion of the rocker cover back. This represents a small patch on the lower front fender, and about 30-40 more inches of surgery, and welding, but miles in terms of peace of mind.. Since the car has no sunroof, and shows no signs of rust forward (other than the front floor indentations), I am pretty confident that the rust diminishes as you go forward.
In other news, I took delivery today of a fully rebuilt M90 engine from Don Lawrence. New pistons, rings, valves, bearings, etc. and a new Schrick cam. This will be mated with my Getrag 265/6 and triple weber carbs using my new custom manifolds. Should be a fun drive!
I have a 3.07 LSD that I was going to use, but I think I may look into changing the ratio to 3.45. The stock M90 in my 635 pushes this same drivetrain impressively well, but I think the 3.45 diff would be more fun, and I don't plan to drive the coupe at 95+ mph on a regular basis.
I'll post pics in an update tomorrow.
Are you sending/paying to have these prototyped in PLA or something else? I can throw these on my printer if you want. Super easy to do. Very cool looking!
Yeah, I sent them to Xometry that printed them in some ABS material. The finish is very good! These are really just templates for checking overall clearances in the engine bay. Once I confirm the fit I'll either have them cast or machined in Aluminum.
Thanks for the offer! I may take you up on it if I need to modify anything.
Definitely! I can print abs/asa/whatever pretty much in the plastic or plastic/cf realm..it would fun to do for those intakes. No charge.
I checked them with the Bambu slicer and they sliced OK with tree supports. Are you referring to the elbow trumpets? I will need to re-run those with a smaller mounting flange. I had not figured on the pair to pair spacing, and the 15 mm flanges I used will just barely clear one another. The new version has a 10 mm flange. But I'll wait to see if there are other changes.
Thanks again.
Thanks again.
Trumpets or the intakes. Yeah, I use a Bambu P1S and it’s pretty good at most stuff. It’s fun to be able to get stuff made…I do need to get trained up on fusion so I can design parts, too. I just can’t seem to find enough time..lol. Happy to help out!
FWIW, I think 3D printing is an amazing evolution in the prototyping world. In years past I would have had to spend hundreds of hours on detailed drawings, and then some machinist would have had to spend hundreds of hours programming a mill, and then if there was an error it would cost thousands to fix.. With 3D printing. you can do a good design, print it, and see how it works, for under $50. And recovering from even minor errors is another $50 (if that)... 5 years ago I would have never imagined I could design a manifold or a trumpet and get one made.
Today. you can 3D print, test, refine and then commit to metal for a tiny fraction of what it cost in the past. Truly amazing..
I also found that the casting world has changed from this. They used to make blanks to create molds. Now they just print the mold in sand based material, and then cast directly. A-MAZING!!!.
If you have any experience with CAD or vector drawing programs, Fusion 360 is pretty easy to learn. There is a free individual version. I found that the key to this program is to understand the "sketch" domain and the other (surface and solid) domains.
The portal between these (and for me it was sketch to solid) is to understand the "plane" construction. The sketch domain starts out with the x, y and z planes highlighted. You then click on the plane you want to work in. The view then rotates to display that plane face on in the display. You can then draw the shapes you want in that plane. . You can then extrude those shapes to form solids (or later to cut solids) orthogonal to that plane. So that allows you to create some oddly shaped flat thing (in my case the manifold flanges). However, unless you want to just raise the solid vertically from the plane you were drawing in, you need to get more sophisticated.
In the case of the manifold I then created a plane that was angled 25 degrees from horizontal (where the first flanges were drawn and extruded), using some guides drawn in the x,y,z, space. I drew the other flanges and extruded them. So now I have two sets of flanges floating in this weird set of planes 25 degrees for one another. In each plane I drew the shape of the outer tube, and then defined an arc between them. Using the "sweep" tool in "Solid". I then created the outer tube as a solid, bent tube. Sweep basically just extrudes a shape (called a "profile" in Fusion) along a defined path (a line drawn in space). The trick here was that, since the space between the intake ports on the head and the bores of the carbs are different (Carbs: 90 mm, Ports: 100mm) the sweep line was a curve drawn on an angle. To draw this I created an angled plane between the center line of the carb bore and the center line of the head port. On that plane I drew a curved arc from one flange to the other. I then swept the outer tube profile along that path. Study the intake images above, and you will probably see this.
To get the hole inside the intake, I did the same thing, except since the profile at one end was circular, and at the other it had that odd shape (SF Don calls it the "epiglottis") I used the "Loft" function. This basically interpolates between two selected profiles, again along a defined path (the same curve angled path as for the outside of the tube). In this case the "loft" was a "cut" instead of a "body, so it extracted the inside of the tube from the solid.
So Fusion really requires thinking about what plane you are drawing in, and then creating other planes to draw the links (guides) between them, and the using one of the solid tools to create a curved solid between the two end points. I'm not sure I explained that very well, but is makes sense in the program. The first manifolds took me days and days to get right. The trumpets I did over coffee in a morning..
I think I must have creates 20+ planes at angles and offsets to create the trumpets.
LMK if you want to go though this sometime on zoom..I'd be happy to show you how it works.
S
S
Man! Thank you for this huge response! I’m going to respond in more detail tomorrow, but I really appreciate this! We’ll be talking for sure!
