73 POLARIS E3 BUILD...Slowly..
that's a tough choice, the e3 looks great in chamonix and it looks great in fjord / riviera / baikal ... since Stephen can't do metallic, that would leave Riviera + Chamonix as great choices from my perspective.
Primer looks great ! I assume your car body "rotisserie" is custom built w/ casters ?
PS: Up on the wall... I noticed that your wall-hung scooters and yard tools are wrapped in plastic in your garage spray booth...
Thanks!
Haha! Yeah, it's a small space for sure...:-). The other side has tons of stuff covered..also why I can't really shoot metallic in there..I can't do it all at once and would have to do multiple days of shooting which just introduces too many variables for matching the metallic 'laydown'.. had that happen on a copper metallic jeep I had years ago..had to reshoot half of it to match...goodtimes.
The body roller is just some scrap steel square tube with heavy casters..without suspension on it, it's too hard to move around. This makes it super easy. Once it's done, I can slice the welds and repurpose the metal and casters for something else..maybe a mobile welding table?
Now I'm changing out the valve cover gasket on my wife's 06 330i...ugh...oil filling the spark plug wells..4 broken bolts I had to drill out...all on the back area of the head...lol. Fun!
@StephenZ : A few posts back you mentioned using Riviera Blue on your car... @HB Chris is selling a 3.0CSi (edit) on BAT in this color. Might give you a few ideas.. the sunlight shots are well done... you can see how this color works on body panels.. when one area is reflecting the sun and another portion is not reflecting the sun..
I've been paying attention to this interaction of body panel shape, color and light because my E3 restoration will not have the body line chrome trim.
I did a spray out of riviera on an e3 fender piece. Nason single stage. It looks pretty solid. VERY different in light vs shade. I think I posted it a while back in this thread. I’m most likely going that direction. I’ll def check out the listing though!
Check out the difference in the sunlight and shade. Pictures taken :30 apart...It's wild. This is whatever the computer told them for the 70s Riviera blue bmw code we use. Nason single stage. I may do BC/CC for my actual spraying to give myself a lot of depth to wet sand a little..
That color change is pretty impressive, but have to say that I like both of them! I'm partial though - the lighter blue looks like the Rivian blue and the darker is similar to my E39's Lemans Blue. I would never imagine both of those in the same vehicle though, so yours will be extra-special.
It's crazy how much it changes, right? I just need the weather to warm up a bit so I can sand the primer and get painting! Meanwhile, I rebuilt the trans and transfer case in my FJ40...that was fun..
