72 3.0 CS 2240344 Restoration
The dancing gauge can probably be remedied simply by placing a capacitor across the gauge terminals.
I'll ask Don how he dealt with the temp gauge. That is one very strange device. I am wondering if perhaps the one i have is inoperative. I cannot get it to register anything other than zero or full scale..and once it goes full scale, you have to drop the voltage down to about 1 volt to get it to come back to zero.
I just found VDO voltmeter that appears to be the right size. I also found a Porsche 911 gauge that has oil pressure onthe right hand side. It looks like the same basic gauge guts as the BMW one, only oil is onthe right hand side, so I can convert that to a volt meter, either swap the needle, or paint the Porsche one...
So yesterday I ordered a couple of other VDO gauges. I am hoping these can replace the wonky temp gauge I have been trying to retrofit into the spare fuel/temp gauge I bought, As noted above, the fuel gauge works fine, and I am pretty sure I can recalibrate it to work with a standard VDO oil pressure sender. The temp gauge seems to be inoperative. It reads zero up to about 3 volts applied, and then jumps instantly to full scale. On the way back down, it stays stuck on full scale until about 0.9 volts, where it instantly drops to zero. I can get the voltage scale to change using resistors, but it still has this jumpy binary characteristic and the hysteresis.
So I found a VDO voltage gauge from a BMW motorcycle that looks like it has the same sort of VDO meter movement (needs to be a lot side pivot zero down meter - otherwise I'd just use another gas gauge meter and turn it upside down.. But that would have zero at the top, which would look odd). . Here is the gauge.
The other one I got is a vintage Porsche 911 gauge that has fuel and oil pressure. This looks like pretty much the same type of meter used in our coupes, so I am hopeful that the oil pressure gauge may be usable as is, just drop it into the BMW housing (after changing the meter face using my sticker, and painting the needle off white). If that is the case, then I'll probably redo m y gauge stickers to swap the voltage and oil pressure right to left (Oil is currently on the left), and recalibrate my fuel gauge to read volts, which should be dead simple... This one is attractive as well because it uses the same meter attachment approach with a stud on the back side for each meter.
Many decades ago I was fooling around with some Detroit created gauges and was disappointed when I realized that the fuel gauge seemed to use a bi-metallic element and a heater coil rather than a wire coil and magnet. This explained why the gauge took a while to come up to full after filling my tank. Cheap and rugged I suppose, and it would prevent the rapid needle movement I'd seen in my VW beetle's gas gauge which is run by a simple mechanical cable run from the gas tank to the dash just over a foot away. I wonder if the temp gauge is a similar sort of type, to reduce fluctuations.
That's what I originally thought, but it is indeed a moving iron type meter movement (a fixed coil with a mega net attached to the needle.
My understanding, after a bit of sleuthing was that the temp gauge had a sort of dead band in the middle to avoid showing rapid swings in temperature, which might freak out the driver. However the meter I have seems to have the opposite behavior. It refuses to stay anywhere in the middle, bit instead resides at one end or the other, depending on a very tiny change in applied voltage. It is possible that I am somehow hooking it up incorrectly, and causing ti to work in the opposite way it was designed.
I suspect the dead band may be created by having some constant magnets inside the armature coil, and it is possible that by hooking it up wrong I am not powering those correctly, but I have tried all manner of ways and get the same behavior.
Took a trip to visit Don today to drop off the Gen 2 dash speaker baffles.
On my way home, I stopped off to see what was up with my car. They have made pretty good progress!
Driver side front floor is in. Passenger side rocker is in. Gaping speaker holes in the package tray are gone. The front passenger floor is removed and ready for replacement. And they have done various body panel flattening. There are a few dents on the right rear quarter that need tending to, and it looks like the rear driver's side passenger floor will also need to be replaced (after blasting it started showing some "lace").
He thinks it should be done in a couple of months...
See post 524 of this thread...
Where: It's coming home from Coupe King in LA.
Why: It's been beautifully restored, and is ready to be put in my car when it gets back from paint..
Received the Porsche gauge today. It looks like the exact same meter dimensions as the one I have been working on, so I'll swap the oil sensor to the right side of the gauge and use the gas gauge meter as a the voltage one on the left side of the gauge. Then I just need to calibrate the voltage one, and figure out which oil pressure sender was used on older 911's. I'm hopeful that it is the common VDO 10-180 ohm unit. Gotta remake the stickers...
So, after spending a weekend away, I finally had some time to check out the Porsche gauge. Internally it is very slightly different, but the meter movements are the exactly same size and mounting configuration as the BMW ones. Here is a side by side comparison. The Porsche meter (red needle) has been mounted to the BMW gauge plate, and has the BMW meter face attached. BMW meter has the white needle (this was the problematic temp gauge from the BMW meter, hence all the resistors connected as I was trying to get it to behave...
And, here is the meter with the + terminal connected to 12 V, the case grounded, and the G terminal connected to ground via a 10 ohm resistor (simulating the oil pressure sender at low pressure). Bear in mind the this is a right hand gauge, so the oil pressure sticker is upside-down. I'll remake that for this side.
And here is the same setup with 175 Ohms in the G side (simulating the oil pressure sender at high pressure).. Perfect!!
So this weekend I'll paint the needle, calibrate the gas gauge to be the volt meter, and order the reversed stickers.
Amazing!!! The ingenuity is phenomenal. I may have to make one of these for the day I decide on AC and have to remove my gauge panel
Aside from being red, the Porsche needles are somewhat thinner and shorter than the BMW ones. I was able to pull the needle off my bad temp gauge so I'll try swapping that one to the Porsche gauge.
Today I am also going to calibrate the gas gauge so that it reads 8-16 volts. I'll take pics of that and post the resistor values.
The Porsche gauge I used is a few posts up. It is from an earlier 911. It has the same VDO side windows and two pairs of tiny black screws holding the meter faces onto the meter body. Unlike BMW, the Porsche meter face is slightly larger, and has no slot at the needle pin, so I had to very carefully cut the meter face to remove it. Fortunately since the meter movement is the same, the mounting holes for the faces are in the exact same locations.
Here is the gauge. There are several on eBay for about $100. If you want to try this project, I'd snap one up..
Porsche Combo Gauge
Here are the meter faces. BMW onthe left, Porsche on the right.
And a couple of pics of the meter bodies. They are definitely different, but the meter guts is the same. It mounts to the body using that slotted nut on the back.
And the removed BMW needle
The one you linked above has the wording in English (“oil”) vs it seems that the one you ordered had German like this one. Any difference between them you think?
That one is oil level, so that will require some calibration. there are two that are oil pressure (no numbers on the scale) that are cheaper. You are not going to use the face plate that says OEL. I The pressure one shoudl mate up directly to the 10-180 ohm sensor. And, they are half the price...
This one would work too, but you can't use the temp meter.
eBay meter
Needle transplant surgery complete.. Easier than expected, if not a bit scary for fear of wrecking the meter or the needle...
As before, ignore the meter stickers, the new ones are reversed.
