Very interesting. I'll probably do that setup. Looks like you have two different systems?
So, I have seen some zinc chromate parts that are matte finish, and some that are very shiny. Ids that a result of starting with a polished part and then plating it? Even your cast parts up in post 75 and 77 look pretty shiny...Scott,
it is one "system"
The table is set up with the following:
Buckets on the front row: cleaning agent (to be heated), then two rinse buckets. The rinse buckets were to be separated, one for the post zinc plating bath and then for post chromating bath.
I no longer use the bath, just a spray bottle to rinse the parts off as I take them out. I do pull the anodes when not plating and keep them in one of the front buckets.
If I ever re-make the top I will likely eliminate those front buckets altogether. I really don't use the cleaning agent bucket much either as I have an ultrasonic cleaner and a bead blast cabinet that do the work more effectively.
Buckets on the back row: Muratic acid bath, zinc plating bath, yellow chromate, blue/clear chromate
On the very back is the power supply for the zinc plating process.
I nickel plated the door strikers and latches on my 635. Those held upwhat happens if you ceramic coat the freshly zinc'd pieces ... will it stay 'bright'? curious ... if that is something we should do to zinc'd parts. thinking of things like the yellow zinc washers on the front of the car or pieces like the trunk latch or even door latches.
For sure it will inctease the life span of zinced parts if you coat them.what happens if you ceramic coat the freshly zinc'd pieces ... will it stay 'bright'? curious ... if that is something we should do to zinc'd parts. thinking of things like the yellow zinc washers on the front of the car or pieces like the trunk latch or even door latches.
This is my next step too! I noticed how poor the casting was on whatever mystery manifolds I have that came with my spare M30. Need to level them out for sure.Found the 12mm, somehow lodged safely in the little tray at the back of the front subframe!
All pulled apart, a fairly quick process. I then got out my glass panel with various grades of sandpaper affixed, sprayed them down with WD40 and went to work.+
I did find that each of the manifolds had some uneven surfaces on both sides, on the picture below you can see some of the bright surface that had not been touched by the sanding process. This is not as accurate as a machine shop by any stretch of the imagination, but should be much closer tolerance now. We will see...
That looks like a Karsundpartz manifold. Same as what is sold by Pierce. The castings are pretty rough!Found the 12mm, somehow lodged safely in the little tray at the back of the front subframe!
