3D Printed elements of air conditioning/ventilation systems.
STEP FOUR:
Engine Bay.
Do you have a bracket for the compressor?
Yes, we have designed a new mount for our compressor from scratch, and it will be CNC and laser-cut next week
Tomorrow marks the official launch of the new, updated full air conditioning system, complete with a detailed description; to mark the occasion, we are hosting an exciting contest with attractive prizes.
Why?
The compressor's electromagnetic clutch draws about 4–5A, but it generates significant voltage spikes when disengaging. This relay is controlled by a safety loop (a thermostat plus a pressure switch) and safely activates the cooling system within the engine compartment.
Although the clutch coil of a Sanden SD7H15 compressor draws only about 3.8–4.5 A during continuous operation, the moment of disengagement presents a critical issue. The coil acts as a powerful inductor; when the power supply is cut off, it generates a high-voltage spike (reaching several hundred volts).
Without a relay, this back-EMF (flyback current) would strike the micro-contacts of a thermostat or a pressure switch directly, causing them to burn out rapidly, weld shut, or even completely melt the control electronics. Notably, the Bosch relay with an integrated diode (0986AH0602) that I have selected is ideal for this application, as the built-in diode suppresses these dangerous voltage surges.
The finale is coming...
