4310316 begins
all
thanks mike
i found the balancer and the flywheel
"excuss me girl if i take a ride
"cause 90 mph is the speed i drive"
excuss me while i kiss the sky"
actually 24 is a dream to drive
Surprise
I have a super special piece of trim im going to add
no one has done this and will be super cool
could you guess what it might be
it very esoteric and stylish
Lady in waiting
Ready to load as soon as it arrives
and so it begins
here to clean all the parts and ceramic the snakes
therre she blows
onward
so figuring out the pulley layouts
seems the original stuff works best
so have an extra m5 alternater and brackets and water pump with the tread type connector if anyone wants them
also extra coils and power steering pump
dissasembled the throttle bodies and linkake
had to clean old paint and junk
regreased the throttle rod neeedle bearings
need engineering
Careful with that engine hoist Alan. I know that the s38 is supported by blocks but it looks a little scary.
attachment.php
groovin
wrapped all the wiring harness with bmw cloth tape
set the injectors and cleaned all the air horns
have an extra m5 alternator new water pump and brackets and powewr steeringh pump if anyone needs them
on the left
plus i have two extra sets of injectyors
onward
fiooled around with the alternater brackets to see which worked best
ended up useing the orig bracket and the m5 alt cause it has the vreg inside for the kdata and the orig power steering pump
worked out well
starting to meld the two harnesses together
Process
Had to grind down the bracket mount for the m5 alternator with the included voltage reulater needed for the kdata unit
worked out well to keep the existing brackets
Onward
Got the snakes back from the ceramics shop
workin on the wiring harness
