4310316 begins
Rota,s
Nice looking drilled, slotted rota. Are they e9 specific? I have only found drilled
for e9!
Holy toledo
Good ole saturday
Finished the insul
Wrapped allthe wiring in cloth tape
redoing the rearend assembly and gas tank
workin my way forward
tahnsk all
so i finally got the gas door in has to be one of the most difficult jobs on the car set the gas tank run the battery line to the rear and set up the brakes in the rear waiting for caliper kits to finish up the brakes time to paint the wheels add new tieres
friday
found some door pannreling in oakland for the butt liner
have a bunch of elephant skin to recover
have the firewall all set up
and used some asbestos mesh to line the frame and inner firewall for the header heat
got the floor in and started on the steering column
back brakes and the sunroof motor
tomorrow going to set uo the headliner
and door complete assemble
cant finish the brakes till i get the caliper kits
yeppee
Sun
So finished the front end and spindles
installed the sunrof motor and cables
]ready for the "headliner which i will document
got the side light in
installed all the trunk trim
except for the sides
sending out all the perimeter trim to be repolished at
johnsons plating in oakland
i left all the trim outside for 2 months and it held up perfect
im really happy with it not being coated
got the front bumber mounts in
and the door latches
will most likely take two days to do the headliner im thinkin on seting the front and back to set up then pull the sides
taunt. Should be a lot of fun.
Ok post pics tomorrow
Scott,
Thanks for your generosity. Is it called a "Motorsports" roundel ?
I think I would be looking for a matching pair though.
movin
something no one does and it really looks unfinished
license plate mounts as they are ugly steel
started on the dash
engine comp coimin along
front brakes done
thanks all
details it was a fiRST PLACE SHOW CAR
WILL BE AGAIN ONLY BETTR BIGGER MOTOR
CANT WAIT TO HERE THE MOTOR RIP
